ᐅ Which Ikea Pax doors are sturdy and durable?
Created on: 19 Jan 2018 08:17
Reojon
Reojon
19 Jan 2018 08:17
Hello everyone, I’m planning to buy an Ikea Pax wardrobe system and now need to decide which doors to choose. My main question is: which Ikea Pax doors are considered especially sturdy and durable? I’m interested not only in daily wear and tear but also in their longevity over several years, particularly regarding the materials, hinges, and surfaces. Does anyone have experience or can recommend which door models are truly robust, even with frequent use? Thanks in advance for your insights and tips!
SUBEN60
19 Jan 2018 08:42
The issue of stability and durability with Ikea Pax doors often depends on the type of door and the material used. Generally, MDF doors with a melamine or foil coating are sturdy but still fairly susceptible to mechanical damage such as scratches or impact damage.
The most durable options are definitely solid wood-covered doors or doors made with a thicker MDF panel and a resilient surface. The hinges used in Pax units are functional and reliable, but if the wardrobe is accessed frequently, it is advisable to check whether they can be replaced with stronger models if needed.
I would avoid glass or mirrored doors if your main concern is stability, as these are more fragile in that regard.
Shawn38
19 Jan 2018 09:26
I have personally used the Pax system with most door types and can say from experience: If you value durability and use the doors frequently, the melamine-coated doors, especially in the matte finish, are an excellent choice.
The surface shows fewer signs of wear, and the doors are generally quite impact-resistant. The hinges also hold up well when properly installed.
Wooden doors are visually appealing but tend to be more prone to dents and moisture damage if not properly maintained.
For care: Avoid harsh cleaning agents to preserve the coating for a long time.
flo-Theres
19 Jan 2018 09:59
It makes sense to consider the stability of the Pax doors in relation to the overall construction of the entire wardrobe system.
The doors themselves are usually not the weakest point, but rather the hinges and their attachment to the carcass.
For long-lasting stability, solid installation is important, and it may be worth planning for additional reinforcements within the door panels.
In my view, there are three factors to pay special attention to:
- Material and thickness of the door
- Quality of the hinges
- Installation and adjustment of the doors
Among the doors, matte melamine surfaces are especially favored by users who prioritize durability.
RAFAEL
19 Jan 2018 10:18
Additionally, I would like to emphasize that the painted doors from the "Pax" series are visually appealing but can develop scratches or chips quickly with frequent use.
Doors with melamine or foil coatings have an advantage in terms of chip and scratch resistance.
Another point: Ikea hinges are designed for standard use. If you expect high stress, you might want to consider more heavy-duty hinges that can be installed later.
Therefore, my recommendation is: for a durable and stable solution, doors with a robust melamine surface and, if needed, better hinges are the most reliable choice.
O
onquinn
19 Jan 2018 10:23
I only used the melamine doors, as they are sturdy. Painted doors are more delicate. You can request hinges from the Ikea service if they ever break.
