ᐅ Which Ikea PAX models are particularly sturdy?
Created on: 4 Nov 2024 08:17
Narmo
Narmo
4 Nov 2024 08:17
I am currently planning the setup of a larger bedroom and am undecided about the IKEA PAX wardrobes, especially regarding the durability and longevity of the different models. My question to you is: Which IKEA PAX models are particularly sturdy, meaning resistant to daily use such as frequent opening, heavier loads, and possibly strain from larger clothing items or bags? I am interested in differences in the thickness of the carcass material as well as the quality of the fittings and shelves. If anyone has specific experience related to stability, potential weak points, or recommended versions, I would appreciate detailed feedback.
koduga
4 Nov 2024 08:43
I can fully understand how important it is to check the durability before buying a PAX wardrobe. I bought a PAX myself two years ago with a width of 150 cm (59 inches) and a height of 236 cm (93 inches), and for me, it was important that the wardrobe stands firmly and that the doors still open smoothly even after frequent use. From my experience, models with a metal frame on the sides are noticeably more stable than those made entirely from wood-based panels. I also find the interior with reinforced shelves useful, especially if you consider how many clothes you want to store. But I hope others will share their experiences here as well—I’m also curious about tips regarding the fittings.
ju_ren
4 Nov 2024 09:12
If you prioritize durability, you should choose the PAX cabinets with metal frames. The metal base support systems are more stable. Doors with soft-close hinges are longer-lasting. That’s sufficient.
Palenar
4 Nov 2024 10:05
To specifically address the durability of the IKEA PAX models, it makes sense to examine the construction and material composition in detail. The PAX series is generally made with carcasses from particleboard (chipboard) panels coated with melamine. The stability here strongly depends on the carcass depth and the design. Versions with a depth of 58 cm (23 inches) offer more stability than those with 35 or 50 cm (14 or 20 inches) depth, as larger dimensions increase stiffness. The interior components also matter: load-bearing shelves are usually made of wood-based materials, while thinner shelves can deform under heavy loads. Metal reinforcements, especially on the side panels and back walls (metal braces instead of thin particleboard backs), significantly improve resistance to warping or twisting.
The door hinges are also important: the soft-close variant not only provides a comfort feature but also a more stable mechanism that retains its function longer. Whether sliding doors or classic hinged doors are used also plays a role: sliding door wardrobes require very precise installation to avoid damaging the tracks over time. Overall, I recommend paying attention to the following details when purchasing:
- Carcass depth of at least 58 cm (23 inches)
- Metal frame or metal brace reinforcement
- Soft-close hinge technology
- Reinforced shelves
I would also like to know what the exact intended use of the wardrobe is. Will it be used mainly as a clothes wardrobe, for heavy items, or for aesthetically open storage?
Narmo
4 Nov 2024 10:42
Palenar schrieb:
I would like to know the exact intended use for the cabinet. Will it primarily serve as a wardrobe, for heavy items, or for open aesthetic storage?
Thank you for the detailed response! The main purpose is clearly as a wardrobe for various types of clothing (shirts, pants, jackets). Additionally, larger bags and occasionally shoeboxes will be stored in the lower sections. Therefore, the cabinet will be used heavily on a daily basis, both in terms of opening and load, as described. A certain level of aesthetics is also important to me, but durability is definitely the priority.
Davidleo
4 Nov 2024 11:07
Awesome topic! I’ve had a PAX wardrobe with a depth of 50cm (20 inches) and soft-close doors for 3 years now, and it’s really durable! The doors work perfectly, and I have quite a few jackets and bags stored inside. Of course, it’s not the "ultimate" heavy-duty wardrobe, but it’s absolutely great for everyday use. I can only encourage you to go for soft-close doors and the 50+ cm (20+ inches) version! 🙂
