ᐅ Replacing KALLAX doors – affordable alternatives beyond IKEA?
Created on: 9 Aug 2022 19:27
Gosau
Gosau
9 Aug 2022 19:27
I am planning to replace the doors of my IKEA KALLAX shelving unit because I no longer like the standard models over time and would prefer a more personalized and, above all, more affordable alternative. My specific question is: What options are there to renew the KALLAX doors inexpensively and independently from IKEA? I am interested in both do-it-yourself solutions and ready-made products from third-party suppliers that are well compatible. Tips on affordable materials or sources would also be great.
I have some DIY skills, so creative solutions involving self-construction or upcycling are also of interest. I understand that mounting the doors and fixing them in place is not always straightforward, so I am open to any advice on installation.
Thank you all for your suggestions!
toril
9 Aug 2022 19:33
Basically, it should be noted that KALLAX doors are not easily compatible with standard doors due to their specific drilling patterns and dimensions.
The most affordable alternative is custom-made MDF or plywood panels, which you can cut yourself and fit with hinges accordingly. Afterwards, you can paint or apply a laminate to achieve an attractive finish.
Pre-cut KALLAX front panels are also available from some Etsy shops or DIY store websites, but the price can quickly come close to that of the original IKEA products.
It is also important to use the original mounting points or adjust them by widening the holes to ensure the doors open and close smoothly.
gilen
9 Aug 2022 20:45
Hello Gosau,
your question is very well formulated and provides a clear direction! If you are considering DIY construction, I recommend using HDF boards. They are relatively inexpensive and can be painted or covered with self-adhesive foil.
There are also various tutorials online that show step-by-step how to use the standard KALLAX fittings and customize the doors individually. If you have tools available, this is a very flexible and cost-effective solution.
Additionally, you could build frames from wooden slats and combine them with plexiglass or thin veneer panels. This gives a more elegant finish without spending much money. You will likely need to make some minor adjustments to the fittings, but this is usually manageable with screwdrivers and a drill 🙂
PLOMA
9 Aug 2022 22:09
I would like to add that when replacing KALLAX doors, the most important thing is to have precise knowledge of the dimensions and mounting systems. Most people use IKEA’s own hinges with those special metal clips that clamp into the KALLAX side panels. If you want to use doors other than IKEA’s, you have two options:
1. Use the original hinge mounting on the KALLAX unit and prepare the doors accordingly, or
2. Install an additional adapter plate to use a different type of hinge.
A step-by-step suggestion:
- Build the door frame from wooden strips 18–22 mm (about 0.7–0.9 inches) wide.
- Cut a medium-thickness MDF panel (10–12 mm / 0.4–0.5 inches) for the door filling.
- Seal the surface with primer and multiple coats of paint.
- Precisely mark the drill holes for IKEA hinges and create clean stepped holes.
It becomes problematic when trying to fit ready-made interior or furniture doors from third-party manufacturers directly, as these are usually too thick or pre-drilled differently.
Additionally, using a thin HPL or CPL laminate coating can create a very durable and modern door design. This is particularly worthwhile if you value longevity and easy cleaning.
One more question for you: What are the dimensions of your existing doors (height and width)? And how are the hinges or mounting systems currently installed?
Gosau
10 Aug 2022 08:21
PLOMA schrieb:
Furthermore, a very durable and modern door design can be achieved with thin HPL or CPL coatings.
Thank you for the detailed information. The HPL option sounds interesting, especially because of its durability. My doors measure 33.5 x 35.5 cm (13.2 x 14 inches) (W x H). The hinges are, as usual with IKEA, metal clip-on hinges attached on the inside of the cabinet, so they clip onto the carcass.
Are there any special considerations for self-made doors with HPL regarding drilling or weight? My cabinet is positioned against the wall; I’m wondering if it will remain stable if the door becomes heavier.
Maybe someone also has experience with combining HPL panels and the original IKEA hinge screws?
toril
10 Aug 2022 09:13
Yes, weight is an important factor. HPL panels are significantly heavier than simple MDF boards, so the hinges and fastenings, especially on smaller KALLAX-style units, should not be overloaded.
The original IKEA hinges are designed for a certain maximum weight – approximately 2-3 kg (4.4-6.6 lbs) per door is a general guideline. Compensating with larger hinges or additional fixing points is often difficult.
Regarding drilling: HPL is very durable, but pre-drilling with a wood drill bit is recommended to avoid chipping at the edges. The drill holes should be very clean and deburred to prevent screws from tearing out.
My advice: If you want to use HPL, choose a panel as thin as possible (around 4-6 mm (0.16-0.24 inches)) combined with a solid substructure (e.g., a wooden frame), so the door is not too heavy but still stable.
