ᐅ Which Ikea Pax wardrobes are especially sturdy?
Created on: 19 Nov 2018 08:43
Nicholas47
Nicholas47
19 Nov 2018 08:43
Hello everyone, I am planning to buy a Pax wardrobe from Ikea that should be especially sturdy and durable. My question is: Which Ikea Pax wardrobes are particularly robust when used intensively every day, for example for heavy clothing or occasionally storing bulky items? I am especially interested in the quality of the materials, the stability of the wardrobe structure, and whether certain designs or combinations (e.g., framed doors, sliding doors, or specific interior fittings) are better in terms of longevity than others. I want to avoid the wardrobe becoming wobbly or having doors that warp after a short time. Thanks for your experiences and recommendations!
elmer
19 Nov 2018 09:12
The Pax cabinet frames made of solid wood are more durable than those made with particleboard. Framed doors appear more stable than sliding doors, as the latter tend to have more issues. For heavy clothing, choose the larger frames and reinforce the shelves with additional supports.
Enrico4
19 Nov 2018 10:05
There are some important points regarding the durability of Ikea Pax wardrobes: - The basic construction usually consists of coated particle boards, which have good load-bearing capacity when assembled correctly. - Wardrobes with framed doors are mechanically more stable and less prone to warping. - Sliding doors may cause problems under heavy use, especially if assembled incorrectly or overloaded. - Reinforcements with additional metal brackets increase stability. - For heavy storage, the stronger "Pax" version with reinforcement kits or options with more robust bottom supports is recommended. In summary, wardrobes with framed doors and extra reinforcements are better suited for intensive use.
sarlo
20 Nov 2018 07:37
I understand that you value durability, especially since a Pax wardrobe needs to withstand daily use. As Enrico4 already mentioned, it is essential to ensure proper installation. A precise assembly with all screws and fasteners is a basic requirement. It also helps not to overload the shelves and to store heavier items at the bottom of the wardrobe to improve stability. Frame doors tend to be sturdier, which I have experienced myself, while sliding doors are more delicate, especially once the rollers have worn down after some time. One tip: consider checking the wardrobe parts in person before purchasing to see if everything is well made. If you like, I can share my experiences with certain models and interior layouts in more detail.
benonon
20 Nov 2018 09:43
To answer your question about the durability of Ikea Pax wardrobes more precisely, I would need a few more details:
- How heavy are the items you want to store?
- Do you mainly need hanging space, shelves, or drawers?
- How often do you open and close the doors daily?
- Do you use the wardrobe in a fixed location, or do you move it frequently?
Generally, the frame models with more solid door construction are more stable because the door frames are made of solid pine wood, which can withstand more weight and some moisture. Frame doors are especially less prone to warping, as they are less affected by humidity compared to full-panel fronts.
A common issue with sliding doors is the track mechanism, which tends to wear out faster under heavy use or dirt buildup, causing the doors to stick. Overall, precise installation with adjustment for floor levelness is crucial, as otherwise the doors may warp.
Reinforcements on the shelves through additional boards or supports significantly increase load capacity, especially when storing heavy clothing or equipment.
Providing more specific details will help me give even more tailored recommendations.
Nicholas47
20 Nov 2018 12:11
benonon schrieb:
In general, frame models with more solid door construction are more stable because the door frames are made from solid pine wood, which can withstand greater stress and some moisture.
Thank you for the information; I hadn’t considered the pine wood aspect. Regarding the intended use: mainly seasonal clothing will be stored, but also occasionally bulkier or heavier items such as bags or winter jackets. The wardrobe will be placed in a fixed location and used about two to three times daily, meaning it will be opened and closed frequently. Inside, shelves and hanging rods are planned, while drawers are less preferred. I’m wondering if the standard PAX depth of 60 cm (24 inches) offers sufficient stability, or if I should opt for the 35 cm (14 inches) version, which is often described as more stable?
