Hello everyone, some time ago I bought an Ikea Pax wardrobe, which is basically very practical. However, I have noticed that under heavier loads – for example, when many heavy garments or boxes are stored inside – the system’s stability reaches its limits. I’m not just talking about a slight wobble when touching it, but also a noticeable strain on the back panel and the supporting brackets, which is starting to concern me.
My specific question is: How can the Ikea Pax wardrobe be made more stable and durable under heavy loads without immediately becoming a professional furniture maker or replacing the entire unit? Are there proven methods, additional reinforcements, modifications, or special accessories that I can use to keep the wardrobe stable and prevent any deformation or damage? I’m especially interested in tips that are not only theoretical but have been successfully applied by others.
Thanks for your help!
To make the Pax truly stable under heavy load, I recommend a three-step approach:
- First: The original back panel is usually thin and mainly serves as a stabilizing sheet. Replace it if necessary with a wooden back panel (e.g., 6 mm (1/4 inch) plywood) that provides significantly more strength.
- Second: Use additional angle irons or L-shaped metal brackets inside the side panels to better distribute the loads.
- Third: Wall anchoring is essential under heavy load; use anchors suitable for the specific wall type.
One common mistake is overtightening the screws of the original fastening or re-measuring the back panel – otherwise, the cabinet quickly loses stability. These measures combined significantly strengthen the carcass.
So, I solved the whole thing with a few clever hacks and recently even turned my wardrobe into a small storage room 😎
Short and sweet: First, I reinforced the back panel with some wooden battens – simply glued along the edges – and also replaced the feet with adjustable leveling feet that I could set at different heights. This makes a huge difference, especially on uneven floors.
And honestly: a real insider tip is using hook-and-loop tape strips to basically fix the wardrobe to the fabric wallpaper so nothing slips anymore! Sounds crazy, but it works perfectly.
Hello LUFO32, your detailed description of the load situation with the Pax wardrobe really resonates with me. Especially under heavy load, unwanted deformations often occur, caused by the weaker back panel.
I would like to add that replacing the original hardboard panel with an 8mm or 10mm thick plywood panel with a good veneer or lacquer finish significantly increases stability. It is important in this step to carefully pre-drill all fastening points to avoid splitting.
I also recommend reinforcing the vertical side panels with additional screw connections, for example using corner brackets or special furniture connectors. An often underestimated factor is the floor level: unnoticed rocking movements can be prevented with height-adjustable furniture feet – please make sure to check whether the support surface is level.
May I ask how your Pax is assembled? Is it just a wardrobe with interior elements, or do you have a combination with drawers? The assembly also affects the load distribution.
glamo schrieb:
May I ask how your Pax is arranged? Is it just a wardrobe with interior fittings, or do you have a combination with drawers? The setup also affects the load distribution.Thanks glamo, good point! My Pax is 200 cm (79 inches) wide and 236 cm (93 inches) high with two doors. Inside, it mainly includes several shelves, two drawers, and a hanging rod. The load is mainly due to heavy winter clothing on the shelves and boxes in the lower drawers. I’m also somewhat concerned about the drawer runners—I wonder if they will hold up permanently under the high weight.
Would additional reinforcement under the shelves help, for example with crosswise battens? Or even an extra central support? If so, does anyone have experience with the dimensions or materials, as Ikea doesn’t provide these?
Looking forward to your thoughts.
