ᐅ How can Ikea Pax wardrobes be used as room dividers?
Created on: 4 Jul 2019 14:23
soneo
soneo
4 Jul 2019 14:23
I am currently planning to rearrange my living space and am considering using Ikea Pax wardrobes as room dividers. I am wondering how to best use these wardrobes not only to visually separate areas but also to functionally divide rooms in a practical way. It is important to me to know how to safely install the wardrobes, whether they should be securely anchored to the wall, and how to possibly design them so that they can be easily accessed from both sides.
I am also interested in your experiences with structural stability, especially when placing the wardrobes in the middle of the room without leaning them against a wall. Is it worthwhile to combine individual units, or is it better to use complete modules?
I would appreciate any tips on fastening options, ideas for room layout, and suggestions for interior design (such as shelving, doors, lighting).
What are your experiences? Are there any particular tricks you would recommend for optimizing the use of Ikea Pax wardrobes as room dividers?
refinar
4 Jul 2019 14:48
Hello soneo,
an excellent question that many face when dealing with similar challenges. I have some suggestions on how you can effectively use Ikea Pax wardrobes as room dividers.
1. Stability: These wardrobes are primarily designed for wall mounting, so I definitely recommend anchoring them when used as room dividers, whether to the ceiling, floor, or by using sturdy connectors between multiple units. This will prevent them from tipping over.
2. Access from both sides: One option is to install segment doors in the back panel openings or arrange shelves and open compartments to allow access from both sides. The Ikea Pax back panels are interchangeable—you can remove entire back panels or replace them with glass for a more open feel.
3. Interior design: Use flexible inserts, clothes rails, drawers, or lighting. LED strips can be easily mounted behind the doors.
4. Combination: Many smaller modules are easier to adapt than one large wardrobe, especially in irregularly shaped rooms.
I hope this helps as a starting point! Feel free to ask if you have more questions.
Nigel
4 Jul 2019 15:04
Always secure the cabinet to prevent the room divider from tipping over. Openable from both sides: remove the back panels, for example by replacing them with shelves.
FIKAPU
4 Jul 2019 15:37
If they are freestanding, be sure to stabilize them with a base plate or special brackets. Otherwise, they are very unstable.
refinar
4 Jul 2019 16:12
Nigel schrieb:
Always secure the cabinet; otherwise, the room divider may tip over. To open from both sides: remove the back panels, for example, by replacing them with shelves.
Exactly, this is a very important point. A loose structure always poses a safety risk, especially in households with children or cats.
Additionally, the individual cabinets can be connected to each other. Using connector fittings like those from Ikea (such as cam lock fasteners), you can create stable runs that are much less likely to wobble.
I also recommend ensuring during installation that the cabinet legs stand on a solid, level floor; otherwise, tipping movements may occur.
FLOLEO
4 Jul 2019 17:08
Hello everyone!
I love how versatile the Pax units are! 🎉 They are great for room dividers because they create these “magic walls” that also offer a lot of storage space.
My tip: consider using glass doors or even open shelves instead of solid doors. This adds a sense of lightness, so the room doesn’t feel so heavy. Plus, you can add small decorations or plants, which makes the space feel more inviting and dynamic. 😉
And very important: play with the height! Cabinets that don’t reach all the way to the ceiling don’t overwhelm the room, and you can decorate on top of them.
Get inspired—it’s definitely worth it!
