Hello everyone, I have a problem with the back panel of my Ikea Platsa wardrobe. The back panel has partially come loose and overall feels quite unstable, especially at the corners. Since I want to modify the wardrobe a bit, I am wondering: what is the best way to fix or replace the back panel in the PLATSA system without compromising stability? Are there alternative materials or methods that are better suited than the original back panels? I would appreciate specific tips on fastening options, suitable replacement materials, or experiences with custom-made solutions.
Leonardteo28 Jan 2021 19:45The original back panel is usually made of thin hardboard, which provides stability through the fastening of the side panels. If you are looking for alternatives, a thinner plywood sheet that can be cut precisely to size is recommended. Advantage: plywood is more stable and less prone to warping. However, make sure to sand the edges smoothly and possibly paint them to prevent moisture from penetrating.
Thanks for the initial tips. A question for better understanding: Is the back panel of the PLATSA fixed only with small nails, or is it also secured by a groove or another mechanism? I have the impression that the stability largely depends on the type of fastening because otherwise the cabinet tends to twist overall.
sarGabriel28 Jan 2021 20:31The back panel is traditionally fixed using only thin nails; there is no groove. Therefore, it can come loose quickly if the cabinet is moved vigorously.
