I am planning to expand my Ikea Platsa system flexibly in my living room. Since the room layout is somewhat irregular, I would like to know how to extend and adjust the Platsa system without compromising its modularity or stability. Specifically, I am interested in the following points:
- Which basic elements or extension parts are particularly suitable for adjusting the system's height and width variably?
- Are there special fastening methods or connecting components to securely and yet flexibly combine two or more Platsa units?
- How does an expansion affect the load capacity and stability, for example, when mixing open shelves and closed cabinets?
I look forward to your experiences and tips, especially regarding extensions that can be used for unusual room shapes.
Oh, Platsa is great for expansion! I arranged my modules on three different sides and kept adding new elements. Important things to keep in mind:
- Don’t be afraid to mix different heights!
- Use the back panels and wall anchors; this keeps everything very secure.
- There are even special corner connectors for corners!
I really love the flexibility – just experiment, there are so many possibilities, even if the space is a bit awkward. This way, you don’t have to commit to a fixed layout!
A few technical points to consider when flexibly expanding Platsa:
- Fasteners: The Ikea connectors for Platsa are galvanized and very robust, allowing for strong side connections.
- Because of the standardized grid dimensions (40 x 40 cm (16 x 16 inches) cabinet depth, 64 cm (25 inches) height, and multiples thereof), the modules can be easily adjusted in height and width, supplemented as needed, or parts replaced.
- Pay attention to stabilization, especially when building corners: angle brackets or additional screws combined with the Ikea connectors increase stability.
- It is best to distribute the weight towards the bottom; open modules like shelves should not be overloaded, as they are generally less stable without a back panel.
- Tip: If possible, plan the expansion in phases and build up gradually to better assess load-bearing.
Are there specific dimensions or load limits relevant to your project?
TEBILO schrieb:
Are there specific dimensions or load limits relevant to your project?Thanks for the tip! The dimensions should fit within the standard plans of Platsa, especially around 40 cm deep (16 inches). In terms of load, I would say a maximum of 20 kg (44 lbs) per open compartment; it likely won’t be much more since mainly decorative items and not very heavy books will be placed there. Closed cabinets could hold heavier equipment such as hi-fi components. It is important to me that the modules can still be easily adjusted after expansions, and, for example, that doors don’t get stuck when I add units around corners.
Manpa schrieb:
In terms of load capacity, I would say a maximum of 20 kg (44 lbs) per open compartment, probably not much more since mainly decorative items and not very heavy books are intended for those.That is realistic and matches the Platsa specifications. Doors tend to stick somewhat with corner solutions if not installed correctly, so I recommend particularly careful alignment here and possibly using adjustable hinges or door dampers for fine-tuning.
It’s a good idea to screw the modules together on site and secure them with the Ikea connectors to prevent later shifting. If needed, you can use special angle brackets for corners, which make installation more convenient.
