ᐅ How can Ikea Platsa be expanded flexibly?
Created on: 9 Oct 2016 08:37
Manpa
Manpa
9 Oct 2016 08:37
I am planning to expand my Ikea Platsa system flexibly in my living room. Since the room layout is somewhat irregular, I would like to know how to extend and adjust the Platsa system without compromising its modularity or stability. Specifically, I am interested in the following points:
- Which basic elements or extension parts are particularly suitable for adjusting the system's height and width variably?
- Are there special fastening methods or connecting components to securely and yet flexibly combine two or more Platsa units?
- How does an expansion affect the load capacity and stability, for example, when mixing open shelves and closed cabinets?
I look forward to your experiences and tips, especially regarding extensions that can be used for unusual room shapes.
Renegi
9 Oct 2016 08:51
It is best to purchase additional side panels and connectors. This way, you can securely attach the modules to each other. For flexibility, the smaller modules with a width of 60 cm (24 inches) are helpful, as they combine well.
benonon
9 Oct 2016 09:15
Your question is good because Platsa offers many possibilities through its modular design, but there are a few points to consider:
- Basically, you can connect as many modules as you want, as long as you securely fasten them with the supplied connectors. Without these, the system may become unstable.
- For flexible height adjustment, it is recommended to combine different grid sizes. Platsa uses 40cm (15.7 inches) depths and heights in 64cm (25.2 inches) and 128cm (50.4 inches) increments. Using intermediate shelves allows you to vary interior heights.
- Regarding stability: If you combine open shelves with closed cabinets, make sure heavy items are placed at the bottom and the assembly is secured to walls or floors. There are special wall mounts from Ikea that are recommended.
- Special extension parts like corner modules or smaller drawer inserts can be useful if the room has an unusual layout.
I am curious: How do you plan to place the modules – more freely in the room or against walls?
Manpa
9 Oct 2016 09:39
benonon schrieb:
I’m curious: How do you plan to position the modules – freely in the room or against walls?
Thank you for the detailed response! The modules are mainly intended to be placed along two walls, one of which is somewhat irregular due to radiators and windows. I want to arrange shelves and cabinets there as flexibly as possible, possibly even around the corner. Freestanding module placement in the room is less planned, as the floor is not perfectly level.
Regarding load-bearing capacity, it’s important for me to know whether I can safely store heavy books and electronics on open shelves without compromising stability.
CHENNE
9 Oct 2016 10:12
Regarding your question about load-bearing capacity and stability, I can say the following:
- The Ikea Platsa modules are designed for average loads, such as clothing or lighter items. Deeper and open shelves do not support the same weight as closed cabinets with a back panel.
- For heavy books or electronics, it is recommended to reinforce the modules with additional back panels and wall attachments. This provides stability and prevents tipping.
- Corner solutions can be achieved with additional connectors, some of which Ikea includes or can be purchased separately.
- Careful assembly of the connectors between individual Platsa elements is essential to maintain structural stability.
If you plan to store particularly heavy loads, combining these modules with other more robust furniture might be advisable.
Ianlau
9 Oct 2016 11:03
I would like to add that when expanding the Ikea Platsa system flexibly, combining open and closed units does require some planning. Especially when arranging multiple modules in a row or around corners, the following approach is helpful:
- Plan to place the heavier and more stable units (such as closed cabinets with doors) at the bottom or as the foundational base.
- Open shelves and units with transparent fronts serve more as accents and are flexible but should not be heavily loaded.
- You can significantly increase stability by using wall anchors, even though the system is originally designed to stand directly on the floor.
For more complex expansion plans, it is also advisable to double all connecting parts and use additional screws for reinforcement when Ikea does not recommend extras. This way, the system can be adapted to a wide range of room requirements.
