ᐅ How can I repurpose Ikea Platsa furniture for use in the bathroom?
Created on: 11 Jul 2019 08:36
BelakarHello everyone,
I am currently considering how to repurpose Ikea Platsa furniture effectively for my bathroom. Since the Platsa series was originally designed as a flexible storage solution, I would like to know what modifications or additions can make it as water-resistant and functional as possible for bathrooms.
I am particularly interested in:
- Which surface treatments or coatings you would recommend for damp environments
- Whether installing additional seals or waterproofing measures is advisable
- Which modules or combinations work best as a vanity unit or shelving in the bathroom
- Experiences with integrating Platsa furniture into small bathroom spaces
I am hoping for practical advice based on real experience rather than just theory. Thank you in advance!
For installing Ikea Platsa furniture in the bathroom, I recommend the following approach:
- Platsa units are generally not waterproof, so an additional coating should be applied, for example, a water-repellent clear varnish based on polyurethane.
- All edges should be treated with acrylic sealant to prevent moisture penetration.
- For use as a vanity cabinet, it is advisable to reinforce the base panels since they usually experience higher loads.
- The installation height should be chosen so that splashing water does not remain in prolonged contact with wood or MDF.
- Modules with doors are well suited for bathroom items, while open shelves can be complemented with plastic baskets to provide moisture protection.
This way, stability is maintained and the furniture becomes suitable for humid environments.
Demetrius11 Jul 2019 09:47gaubla schrieb:
All edges should be sealed with acrylic sealant to prevent moisture penetration.That’s a good tip, thanks for that! I’ve experimented with Platsa myself and found that moisture mainly causes issues in unprotected joints.
I would also add that placing suitable moisture absorbers in the bathroom can help when air circulation is limited. This reduces the long-term risk of mold growth and damage to the furniture.
Anyone tackling a project like this for the first time shouldn’t be discouraged, because with some patience and care, it’s enjoyable and you can actually get multifunctional furniture that’s affordable.
I wanted to briefly revisit the basics: Ikea Platsa is modular and mostly made from particleboard with a melamine coating. These materials are not originally designed for wet areas.
Therefore, the following points should be considered when converting it for bathroom use:
- It is very important to carefully seal all cut and drilled surfaces.
- For reinforcement, waterproof plywood panels can be used as a base.
- There are options to protect the fronts with water-resistant films or coatings.
- Depending on the design, a combination of closed cabinets for towels and open shelves for decorative items is recommended.
- It is also important not to place the furniture directly on the bathroom floor (for example, using feet or baseboards) to prevent water damage.
I am happy to answer any questions on this!
gaubla schrieb:
The installation height should be chosen so that splashing water does not consistently reach wood or MDF.I always wonder with such advice whether it is truly practical. In a small bathroom, it is often hardly possible to install furniture completely outside splash zones.
This means that if you want to repurpose Platsa, the question of the general water resistance of the materials should be reassessed.
Has anyone ever been advised to cover the entire system with a waterproof layer—such as epoxy resin or something similar? My research shows that this can provide a durable solution, but the labor and costs increase significantly. A trade-off, in my opinion, that should not be underestimated.
