ᐅ How can I recycle or upcycle IKEA PLATSA furniture?
Created on: 3 Apr 2021 08:13
Frase70
Frase70
3 Apr 2021 08:13
Hello everyone, I have some IKEA Platsa furniture that I no longer want to use for its original purpose, but I also don’t want to just throw it away. Therefore, I’m considering how to best recycle or upcycle the Platsa furniture. Does anyone have specific ideas on how to transform the individual parts (frames, shelves, doors) into new uses? I’m particularly interested in which woodworking modifications make sense, how to disassemble them without damaging the materials, and whether there is any kind of environmentally friendly way to dispose of the leftover pieces. Additionally, I’m curious about how to easily change the typical light-colored furniture surfaces so they look good in new contexts. Thanks in advance for your tips and experiences!
GAGRAHAM
3 Apr 2021 08:35
Oh, great question! IKEA PLATSA is really easy to upcycle—you just need to get creative! 🎉 I once made small shelves for plants out of it and painted the doors with bright colors. It’s important to remove the screws and parts carefully—I prefer using a cordless drill with bits that fit perfectly. When you take the panels apart, you can sand them down easily and then repaint or cover them with adhesive foil. This way, they look much more personalized and the style stays fresh. You can usually use leftover wood pieces as firewood or for craft projects! Have fun experimenting—it’s really enjoyable! 😄🌿
praWarre69
3 Apr 2021 09:08
Ah, here’s something practical for spring cleaning! 😎 I had similar ideas before and repurposed doors from PLATSA as decorative wall shelves – basically turning the doors into small shelving units with hooks, which works great for bedrooms or hallways! 😅 A tip: you can paint the surface with chalk paint, which can even be easily wiped off if you want to change something later. And because the material is lightweight, painting is quick and easy. You can also use any leftover pieces for upcycling projects like small boxes or trays – make sure to keep the small parts, as screws are gold when rebuilding.
boelnu
3 Apr 2021 10:22
I understand the desire not to simply throw away PLATSA, as being sustainable is important to me as well. To be honest, I had some difficulties disassembling it because the panels can be somewhat fragile. My advice would be to carefully loosen all the connectors, especially the metal clips, to prevent the edges from breaking. After that, you could, for example, reuse the back panels as pinboards by covering them with fabric. And if you have no way to repurpose the parts, some local recycling centers accept furniture waste. I hope this helps a bit with sustainable handling.
U
usron
3 Apr 2021 10:59
Hello! I completely agree that IKEA PLATSA has great potential for upcycling! 👍 I built a small workbench for the garden using old doors, simply treated the surface with wood oil – it looks great and is weather-resistant. The frames are sturdy enough for this purpose! If you want to take the furniture apart, patience helps more than anything, and a good screwdriver is invaluable. Power tools are even better, of course! 😉 For anyone interested: don’t hesitate to try remodeling it yourself, the result is really rewarding and environmentally friendly.
Fitigu
3 Apr 2021 11:34
For systematic handling: PLATSA furniture mainly consists of particleboard with melamine or foil coating. When dismantling, it is advisable to unscrew the fasteners using appropriate tools, as glue joints are usually absent. The surface is sensitive to mechanical impact, so separation should be done carefully to preserve the usability of the panels. Visual changes can be effectively achieved by lightly sanding and applying chalk or acrylic paints. Water-based paints are environmentally friendly and gentle on the material. For disposal: Residual household furniture is generally accepted as bulky waste or at municipal recycling centers. Furniture wood is often thermally recycled; traditional recycling methods are complex for this type of furniture.
