I am considering getting the Ikea Platsa system, but my usage situation is a bit special: I will likely rearrange the furniture regularly because I am redesigning my apartment and want to remain flexible.
My specific question is: How stable are Ikea PLATSA furniture pieces when they are moved and disassembled frequently? Does the stability or fit of the connections deteriorate with repeated assembly and disassembly?
I am particularly interested in the durability of the screw connections, the hinges, and the material itself. Are there users who have assembled and rearranged the furniture multiple times and can share whether the pieces become wobbly or show any damage over time?
I look forward to your experiences and insights. Thanks in advance!
Regarding stability and repeated disassembly, here is a brief step-by-step guide for handling Platsa:
1. Always loosen and tighten screws in the specified sequence.
2. When assembling for the first time, tighten carefully without overdoing it.
3. After each rearrangement, retighten all connections.
4. Fill any loose drill holes with wooden dowels to maintain stability.
5. Check the back panel before installation; it must be flat and undamaged.
By following these simple steps, you can significantly improve stability during repeated rearrangements.
fredle schrieb:
Tighten all connections after each repositioning.This is definitely an important point that I hadn’t explicitly considered before.
Thank you all for the valuable information and advice!
It is now clearer to me that PLATSA can be used with regular repositioning if done very carefully, with screws checked regularly and minor repairs like wooden dowels applied when necessary.
I will take a closer look at the reinforcement elements. That could be the solution to keep the furniture stable for longer while still remaining flexible.
