ᐅ How can I use IKEA PLATSA furniture in versatile ways?
Created on: 20 Jul 2018 08:14
Rikelo
I have some IKEA Platsa furniture in my apartment and am considering how to use these modules more flexibly. The system’s adaptability seems ideal for making the best use of space, but I’m missing some concrete ideas on how to creatively and functionally combine the modules beyond the usual cabinet and storage solutions.
I’m interested in:
- What unusual uses have you discovered for Platsa?
- What tips and tricks do you have for optimizing space with this system?
- Are there any innovative modifications, such as multifunctional furniture, that you have implemented?
It would also be important for me to hear about any experiences with stability when using altered constructions or custom adjustments.
I look forward to exchanging ideas and getting lots of inspiration!
Demetrius
20 Jul 2018 20:11
I find the idea of converting Platsa for multifunctional use quite exciting, although I am aware of the uncertainties involved in maintaining both safety and appearance.
DUUS32 schrieb:
Sometimes it really takes courage to rethink existing furniture.
That really resonates with me. It took me a while too, but especially the exchange of ideas and the variety of possible combinations offer plenty of room for creativity. My recommendations:
- Build small test modules on-site before making larger investments.
- Participate in forums like this one to get tips on assembly and stabilization.
The possibility to combine PLATSA with other DIY elements (e.g. cushions, casters, lighting) also makes it very versatile.
bupar
21 Jul 2018 07:22
Here is a brief overview of possible uses that go beyond standard storage:
- Room dividers with built-in storage that visually separate spaces without reducing their size.
- Storage benches that become multifunctional with a padded cushion on top.
- Combinations with work surfaces as small home office solutions in living rooms or bedrooms.
- Open shelving systems for decoration, plants, and everyday items, combining storage with ambiance.
From a technical standpoint, it is important to secure all modules on at least one side to increase stability. Ensure even weight distribution and avoid stacking modules without proper fastening.
flo-Theres
21 Jul 2018 10:46
I would like to highlight the adaptability of the PLATSA modules in terms of design style and functionality.
Thanks to their neutral design and the choice of surfaces in white or wood finish, the furniture can be integrated almost seamlessly into various styles. With some DIY skills, you can:
- Arrange doors and drawers individually or leave them out for open modules.
- Add extra worktops, seat cushions, or LED light strips.
One important point I want to emphasize: Before making any custom modifications, always check that no load-bearing elements are cut or weakened to ensure safety.
Rikelo
21 Jul 2018 14:18
Giagau schrieb:
For custom alterations, please keep in mind: distribute weight evenly, do not overload modules, and consider the load-bearing points.
Thank you all for the many helpful tips! The advice regarding fastening and stability is especially important to me, as I am indeed planning several versions with seating areas.
One more question: Has anyone had experience integrating PLATSA into small hallways? I’m looking for a solution that provides storage space, a seating area for putting on shoes, and room for coats – basically a compact wardrobe solution. Is this modular system recommended for that, or is it rather bulky?
JOHNATHAN
21 Jul 2018 16:20
Rikelo schrieb:
Has anyone had experience integrating PLATSA into small hallways? I’m looking for a solution that provides storage, a seating area for putting on shoes, and space for coats—in other words, a compact entryway solution.
We have it set up exactly like that! PLATSA units with a shallow depth that function as a bench. Above them, we installed open hooks for coats and a small cabinet for shoes. The modular design allows you to fill the hallway precisely, which is often difficult with standard furniture.
If you use rolling boxes, you can even move everything as needed. Some people also use a unit with doors to neatly hide frequently used items. It instantly makes the hallway more organized and inviting.
One tip: a sturdy seat cushion adds comfort—foam-based, which you can cut to size yourself.
miAlessio
22 Jul 2018 08:39
Rikelo schrieb:
I’m looking for a solution that offers storage space, seating for putting on shoes, and room for jackets – basically a compact wardrobe solution.
I’ve put together a small DIY plan for this:
- Base: A flat, low PLATSA cabinet used as a bench.
- Attach a self-made cushion on top (for example, with Velcro strips for easy removal).
- Install free-standing or wall-mounted hooks on the side or above for jackets; you can also hang baskets for gloves or similar items on these.
- Optionally, add small rolling shoe cabinets underneath that you can pull out as needed.
- Mount the hooks on the wall, and optionally add rails for extra stability.
Advantage: You can customize the components to your needs and hallway size, keeping it flexible. A visually neat finish is achieved with matching colors and clean lines.
Just keep in mind: Before installation, measure how much weight the furniture needs to support to prevent tipping.
