Good morning everyone, I need your experience: How can I quickly disassemble IKEA Platsa furniture? I have several combined cabinets that need to be rearranged now. It is important to me to find a method that protects the floor but also saves as much time as possible. Does anyone have tips on where to start first or if special tools can make the job easier? I have already tried to loosen the metal connectors without instructions, but it doesn’t go very smoothly. Details about screw types or other connections would also be helpful. I appreciate any advice!
Thanks for all the advice! One thing is still not entirely clear to me: Some Platsa modules have a back panel that is just slotted in, while others are fixed with screws. What is the best way to handle the back panel? Should I unscrew it first or separate the furniture piece before removing the back panel? Is the back panel material delicate during disassembly?
bole6 schrieb:
Some Platsa modules have a back panel that is simply slotted in, while others are fastened with screws.In Platsa modules, the back panel is usually a thin, pressed board that is secured either with small nails or screws. To maintain stability when separating the modules, it is best to remove the back panel afterward. Loosening the screws allows the back panel to provide some shape stability, which makes disassembling the modules easier. If the back panel is only slotted in, you can carefully pry it off with a spatula, but be careful not to bend the material.
I agree with angel. Also, when dismantling quickly, there is no significant advantage in removing the back panel before separating the parts. First separate the components, then remove the back panel. This way, you reduce the risk of the back panel cracking or tearing during separation. I have used this method during several moves and gladly accept the little extra effort to avoid damage.
PECLARISSA22 Oct 2022 15:16bole6 schrieb:
How can I quickly disassemble IKEA Platsa furniture?Well, on one hand, it sounds like straightforward screwdriver work, but on the other hand, it’s a bit like playing Tetris! My tip is to work rhythmically during disassembly – remove the fronts, take out the internal panels, then systematically target and loosen the connection points one by one. Imagine the furniture dancing before it comes apart. It might sound a bit quirky, but this approach helps you stay focused and avoids random fumbling. It saves both time and stress!
PECLARISSA schrieb:
One tip from me is to dismantle in a rhythmic way – remove the fronts, take out the internal parts, then sequentially locate and release the connection points.Exactly, structure is crucial with this kind of furniture. Especially when you have multiple units connected, it makes sense to always follow the same pattern to avoid missing anything. I would also recommend labeling the panels and parts clearly in case you need to reassemble later.
A technical note for quick disassembly: Some Platsa variants use different metal connectors, including so-called Minifix connectors. If you can’t find a rotation point with the usual Torx bit, try using a suitable flathead screwdriver to release the cam connection. Especially with older models, gently levering the metal can help unlock the connector. It is advisable to proceed carefully to avoid damaging the furniture for reassembly.
