ᐅ How can I recycle or upcycle furniture from Ikea PLATSA?
Created on: 27 Mar 2024 08:17
LIRIDONADU
Hello everyone, I have some furniture from the Ikea Platsa system that I no longer want to use in its original form. Since I generally value sustainability and want to create as little waste as possible, I’m wondering about the best ways to recycle or upcycle this furniture. The system consists of modular elements—cabinets, shelves, doors, and so on—and I have quite a few pre-assembled parts and individual components here.
I’m less interested in simply disposing of or dismantling the furniture, and more in creative ideas for upcycling. Does anyone have experience with transforming an old PLATSA cabinet, for example, into a new piece of furniture that serves a different purpose? How can the parts be reused effectively without completely taking them apart? Additionally, I would appreciate tips on surface treatment or changing the appearance, because the typical light design no longer fits my living room.
I look forward to any input, whether it’s craft advice, materials, tools, or example projects.
LIRIDONADU
28 Mar 2024 09:11
likuken schrieb:
I would much rather recommend, if you want to be sustainable, to completely disassemble the system and recycle the materials separately or feed them into proper material cycles.
Thank you for the critical remark, likuken. It is true that the ecological impact is largely determined at the very beginning of the product life cycle. However, with Platsa, there is the advantage that the furniture can be relatively easily taken apart due to its modular construction. This is often not possible with continuously glued furniture.
What interests me is precisely this possibility of multiple uses. I find todunar’s idea of recombining individual elements particularly appealing.
One more question for everyone: Does anyone know ways to securely connect new furniture combinations without fully relying on the original screws? I am thinking of dowels, glue, or small brackets that can make the furniture long-lasting — without completely losing flexibility.
LOGEMIN
28 Mar 2024 11:25
Hello everyone, I’d like to share some practical tips for modifying PLATSA furniture!
1. First, completely disassemble the furniture and remove any old screws that have become loose. This creates a solid foundation.
2. Join the wooden panels using wooden dowels. For this, accurate drilling is essential – properly fitted dowels provide a stable and concealed connection.
3. Applying glue to the dowels and contact surfaces adds extra strength, especially for larger pieces of furniture.
4. Metal brackets are great if you want corner reinforcement. Make sure to place them on the inside to avoid affecting the appearance.
5. For surface finishing, I recommend sanding with fine-grit sandpaper, then applying a primer followed by a durable paint – for example, acrylic lacquer.
Common mistakes include poor stability due to improperly positioned joints or applying paint layers that are too thick, which can cause chipping.
If you want to repurpose the furniture, plan the load-bearing requirements and cutouts before starting the modification. Always keep in mind the load capacity of the particleboard – too many drill holes weaken the material.
I hope this helps you and everyone else sharing here!
Tofra45
29 Mar 2024 07:16
Disassemble PLATSA, sand the wooden panels.
Reassemble using wooden dowels and glue.
Finish the surface with chalk paint or varnish.
Use metal brackets for stability, especially at the corners.
todunar
29 Mar 2024 12:34
LOGEMIN schrieb:
Typical mistakes include lack of stability due to poorly made joints or applying paint layers that are too thick, causing them to peel.
So true! In my first upcycling project, I didn’t use any metal brackets, and one side panel almost fell off 🙈 Since then, I always recommend using a few extra screws and brackets. It’s better to have a bit more stability than something too wobbly.
One more tip: wood oil keeps the surface breathable and protects the material if you like the natural look. For those who prefer paint, chalk paint is great because it sticks well even without much surface preparation.
I think it’s worth being a little brave and experimenting – upcycled PLATSA furniture is the perfect base for creating unique designs! 😊
Nathanaelk
30 Mar 2024 14:02
LIRIDONADU schrieb:
One more question for everyone: Does anyone know ways to securely connect new furniture combinations without using all the original screws? I’m thinking of dowels, glue, or small brackets that make the furniture durable in the long term – without losing complete flexibility.
Hello LIRIDONADU, I can add the following: If you don’t want to fully screw the furniture together, cam lock fittings, which Ikea sometimes uses, are a good option. They provide a strong connection while allowing for easy disassembly.
Alternatively, you can use metal connectors with hinge functions to keep the setup modular and flexible. It’s important to drill deep enough and choose the correct dowel diameter (usually 8 mm for 18 mm (0.7 inch) panels).
For high long-term strength, you can also use PU glue or waterproof wood glue.
If you send me a photo or describe the dimensions of your existing parts, I can recommend the most suitable connection methods more precisely.
In principle, combinations of dowels, glue, and brackets are the preferred solution for sturdy constructions with partial flexibility.
