ᐅ How do I properly attach the back panel on an Ikea PLATSA unit?
Created on: 20 Apr 2017 08:37
Sudufar
Hello everyone, I recently assembled a Platsa shelving system from Ikea and now I’m wondering how to properly attach the back panel.
Specifically, the back panel is made of thin particle board that fits into grooves and rabbets. My question is whether this is really sufficient, or if I should additionally use screws, nails, or special clamping strips to ensure long-term stability.
Also, I’m unsure if the back panel should be secured before assembling the frame, or if it’s better to fasten everything at the end.
I’d appreciate it if you could share your experiences with the PLATSA system—especially how you attached the back panel, if you used any special tricks or tools, and if there are any important details to keep in mind.
Thanks in advance for your advice!
blaki
20 Apr 2017 12:43
Hi Sudufar, I find this topic interesting because I recently assembled my Platsa myself.
I only installed the back panel at the very end, after the main frame was fully assembled. The nails are small, but if you hammer them in carefully and evenly, they actually hold very securely.
My tip: don’t hammer the nails in with full force, as you might damage the back panel. In my experience, the wood fibers provide enough grip if you proceed gently.
And don’t worry about vibrations — I have the furniture in my living room where there is some movement, but the back panel has remained just as stable after several months.
A little saying: “The back panel may be thin, but it provides stability.”
theota
21 Apr 2017 07:16
I have to respectfully disagree a bit—nailing the back panel in place and calling it a day? To me, that’s more of a temporary solution.
Here’s how I see it: For a piece of furniture you want to use for a longer time, it’s often necessary to secure the back panel more firmly than Ikea usually recommends.
Why? The thin fiberboard isn’t designed to hold permanent loads with just small nails. Over time, these can loosen, especially if the furniture is moved or loaded.
There are definitely options to fix the back panel more securely, such as adding screws through the back of the carcass or reinforcing it with small wooden strips on the inside.
Sure, this is a modification, but I believe it’s worth it if you want quality.
Just a thought—Ikea builds for standard needs, but sometimes a little extra effort pays off.
What do you all think about this?
U
umberto
21 Apr 2017 07:45
Theota, at PLATSA the system is designed so that the back panel only serves as bracing. Using too many screws risks damaging the structure. Nails are sufficient.
Declan55
21 Apr 2017 08:22
Hey everyone! I’m really impressed with how clever Ikea is with the PLATSA system. An entire wardrobe made from modular parts – brilliant!
Regarding the back panel: I always attach my back panel carefully using nails, and after months, it’s still rock solid!
Don’t lose confidence if the back panel feels a bit wobbly at first; that settles over time because the wood naturally moves a little.
So: if you slide the back panel in evenly and nail it neatly, you’ll quickly have a very sturdy piece of furniture.
Have fun building! You’ve got this!
Sudufar
21 Apr 2017 09:05
theota schrieb:
For a piece of furniture you plan to use for a long time, it’s often necessary to attach the back panel more securely than Ikea recommends.
Thank you for the honest assessment! I appreciate you bringing this up. I want to use the furniture for a long time, but it will mostly be a stationary piece in my apartment and won’t be moved around frequently.
So that seems to be the standard recommendation.
Demetrius schrieb:
Do you intend to move the furniture often, or will it mostly stay in one place?
The furniture will stay in one spot and won’t be moved often.
I’ll follow your advice about installing the back panel and nailing it carefully—I plan to attach it at the very end and hammer the nails in gently.
Thank you all for the detailed information; I feel more confident about the assembly now!
