ᐅ How can I recycle or upcycle IKEA PLATSA furniture?
Created on: 3 Apr 2021 08:13
Frase70
Hello everyone, I have some IKEA Platsa furniture that I no longer want to use for its original purpose, but I also don’t want to just throw it away. Therefore, I’m considering how to best recycle or upcycle the Platsa furniture. Does anyone have specific ideas on how to transform the individual parts (frames, shelves, doors) into new uses? I’m particularly interested in which woodworking modifications make sense, how to disassemble them without damaging the materials, and whether there is any kind of environmentally friendly way to dispose of the leftover pieces. Additionally, I’m curious about how to easily change the typical light-colored furniture surfaces so they look good in new contexts. Thanks in advance for your tips and experiences!
boelnu
4 Apr 2021 09:13
I really appreciate how dedicated you are to topics like sustainability and upcycling. Here’s a bit of my experience with films or laminates: I once tried warming the film with a hairdryer and then carefully peeling it off. This worked better than sanding because the surface wasn’t damaged. However, it requires a lot of patience and a delicate touch; otherwise, the film tears unevenly. For items stored in the basement, I would recommend using wood coatings with moisture protection, but the room also needs good ventilation to prevent the wood from rotting. Your tips are truly inspiring!
Tudogo
4 Apr 2021 10:04
boelnu schrieb:
I once tried warming up films with a hairdryer and then carefully peeling them off.
Very good tip! Heat softens the films and makes them easier to remove without having to sand down the panels. After removing the film, the surface can be smoothed and resealed. For wet rooms, I recommend applying a primer plus waterproof coating, which protects against rising moisture. If you don’t mind the extra work, I would prefer solid wood or furniture specifically designed for such areas in basements or bathrooms, as the chipboard used in Platsa is only moderately moisture resistant.
