ᐅ How can IKEA Pax wardrobes be installed without damaging the wall?
Created on: 5 Jun 2019 17:12
Panagiotis
Panagiotis
5 Jun 2019 17:12
Hello everyone, I plan to install an IKEA Pax wardrobe in my apartment. The issue is that I need to securely fasten the wardrobe to the wall to prevent it from tipping over—especially important with children or uneven floors. However, I want to keep the wall as intact as possible since we rent the apartment and don’t want to cause any damage.
My question is: How can IKEA Pax wardrobes be safely secured to the wall without causing significant damage or large holes? Are there specific methods or materials that provide strong support while minimizing impact on the wall? I would appreciate any helpful experiences or advice.
Guyju
5 Jun 2019 17:45
Hello Panagiotis,
Your question is very important, especially in rental apartments, as wall damage can often lead to costly repairs. I will try to answer the topic in a structured way:
- First: Secure mounting usually means you need to use anchors and screws that are properly fixed in the wall. Simply relying on the stability without screws usually doesn’t work for such large furniture.
- If your wall is made of drywall (plasterboard), it helps to use cavity anchors or special drywall anchors. They do leave a hole but distribute the weight and can be removed with less damage.
- Alternatively, you can attach a narrow wooden batten, securely fixed with anchors, and then fasten the wardrobe to it. The wooden batten can be repaired or repainted more easily later.
- If the wall is solid, for example concrete or brick, heavy-duty anchors are suitable. Important: the holes must be drilled precisely to avoid larger cracks.
- If you only want to secure the cabinets against tipping and they are heavy, an additional ceiling beam or a support piece attached to the furniture can help without drilling into the wall.
Summary: Completely avoiding holes is difficult, but with the right anchors and fastening techniques, you can keep damage minimal and easily repair the wall afterwards.
If you provide more details about your wall construction, I can give you more tailored recommendations!
LEEJU
5 Jun 2019 18:00
Hello Panagiotis, just secure it with the IKEA-specific wall brackets and suitable anchors for your wall. Use drywall cavity anchors for plasterboard, otherwise choose the appropriate anchors depending on the wall type. This way, the cabinet will hold well and the holes will be minimal.
Jonna62
5 Jun 2019 18:03
I would recommend checking for cables and pipes with a detector before drilling. For rental apartments, special mounting tapes or clamp holders are often helpful – but these are less sturdy than screws.
Laurence
5 Jun 2019 18:35
Hello everyone, I also find this topic very interesting, as I recently assembled a Pax wardrobe myself.
Regarding Panagiotis: Safety is the top priority, especially when children are in the house. You are right, damage-free solutions are desirable, particularly in rental apartments, but they are often difficult to achieve.
One idea, if you are dealing with a drywall (plasterboard) wall, is to use heavy-duty cavity anchors (toggle bolts), as these open up behind the wall and distribute the weight very well.
If you don’t want to drill, you can also use tension rod systems that fit between the floor and ceiling or wall. These over-the-door units can prevent tipping without the need to drill holes.
However, these solutions are often more cumbersome and not as secure as screwed-in options.
My advice: Consider which is more important for you – minimal damage or maximum safety. Sometimes a small hole and a good anchor are the better choice when safety is the real concern. If you decide to go with screws, make sure to check your rental agreement about whether you need to remove or fill the holes afterwards.
I hope this helps!
Panagiotis
5 Jun 2019 19:20
Guyju schrieb:
If you specify your wall construction in more detail, I can give you more precise recommendations!
Thanks, Guyju, good idea. The wall is a standard concrete wall with a conventional plaster finish, not a drywall partition. About 10 cm (4 inches) thick. Drilling won’t be a big issue, of course, but I was concerned that the plaster layer might crack or that unattractive holes could remain afterwards. Are there any tips to protect the plaster as much as possible and minimize marks when removing screws?
