Hello everyone, I am currently planning the setup of a new bedroom and considering using IKEA Pax wardrobes, as I have read that they are very flexible. My question is a bit more specific: Which IKEA Pax wardrobes are particularly versatile when it comes to individual customization, for example regarding different interior layouts, variable doors, and modular expansion options? It would be helpful if you could also share practical experiences or example configurations that demonstrate the best ways to adapt a Pax wardrobe to different room situations or usage requirements. Thanks in advance for your input!
Basically, all Pax systems are very flexible because they are modular and can be configured quite freely in height, width, and depth. I find the series with wardrobe depths of 35 cm (14 inches) and 58 cm (23 inches) particularly noteworthy, as they allow you to choose between compact and more spacious options depending on the available space. The combination of different interior fittings – shelves, drawers, clothes rails, and wire baskets – also enables a highly individual use. My tip: use IKEA’s planning software, as it is the best way to explore the flexibility.
I think the Pax wardrobes are the chameleons of closets. 😄 Whether with sliding doors or regular doors, you can really make use of every centimeter (inch). What’s especially cool is that you can even swap out interior components later if you want to change the function – from a wardrobe to storage for technical equipment or books, just like that. For people who like to redecorate or reorganize, Pax is almost unbeatable!
Interesting points about flexibility. However, I wonder if modularity might come at the expense of stability. I would be interested to know if anyone has experience showing that these adjustable interior fittings can really withstand everyday stresses – especially when the cabinet is frequently reconfigured. Also, how well do these systems actually work in small, irregularly shaped rooms? There’s a lot of positive feedback, but real-life use can be different.
I can provide clear information about the load capacity of the Pax wardrobes: The standard Pax units are designed to support up to 10 kg (22 lbs) per shelf, and even more for hanging rods. The modular construction ensures a stable structure as long as the wardrobes are properly assembled and secured to the wall. For small rooms, I recommend the narrower models with a depth of 35 cm (14 inches), as they fit well into recesses. The internal components have been tested according to ISO standards and maintain sufficient load-bearing capacity even when repurposed.
When it comes to flexibility, I find the option to choose the type of door particularly important. Sliding doors save space and are ideal for tight areas, while folding doors are especially low-maintenance. The different front options, ranging from acrylic glass to wood and mirrored fronts, also significantly expand the possible uses – allowing you to adapt the wardrobe both visually and functionally to the room.
