ᐅ What mounting methods are available for Ikea Pax to support heavy loads?
Created on: 21 Jun 2024 08:17
RI-TAR
RI-TAR
21 Jun 2024 08:17
Good morning everyone, I am currently planning to assemble an IKEA Pax wardrobe system that needs to support heavy loads. Therefore, my question is: which mounting methods are the most effective and secure for IKEA Pax when it comes to carrying particularly heavy weights? I am especially interested in which wall anchors, types of screws, or additional reinforcements IKEA recommends or users suggest in practice to ensure a stable setup with high load capacity. A detailed overview or experiences with different installation methods would be very helpful.
Maria35
21 Jun 2024 08:45
Basically, IKEA’s Pax system uses included metal brackets to attach the wardrobe to the wall at the back. This fastening is designed for normal loads such as clothing, small boxes, etc. For heavier loads, the following approach is recommended: - Use heavy-duty anchors (e.g., Fischer UX or expansion bolts) suitable for the wall type (concrete, brick, drywall) - Additional reinforcement with an OSB board or multiplex panel behind the wardrobe, screwed into the wall to better distribute the load - Attach the included brackets to load-bearing points, not just drywall - If possible, screw directly into the studs of the drywall using appropriate cavity anchors - In some cases, strengthening the wardrobe base or adding a center support can improve load distribution - It is important to accurately assess the wall and load conditions to select the suitable anchors. Unfortunately, IKEA does not provide specific recommendations for very heavy loads.
Palenar
21 Jun 2024 09:12
[@Maria35, post: d0h4n0, member: XXX]
Basically, IKEA’s Pax system relies on supplied metal brackets to secure the wardrobe to the wall at the back. This fixing is designed for normal loads such as clothing, small boxes, etc.
Exactly, I would like to add: The standard brackets usually attach near the top edge of the wardrobe. If the wardrobe is filled with heavy loads, there is a risk that the screws will pull out of the wall, especially with drywall. In this case, an additional mechanical connection is recommended, for example:
- Installing a wooden or plywood panel on the wall, which is screwed into the load-bearing parts of the wall. The wardrobe is then fastened to this panel
- Using heavy-duty anchors with proven high load capacity – starting from 50 kg (110 lbs) per anchor, depending on the wall
- Additional pinning of the wardrobe’s back panel and possibly fixing it to the floor to minimize tipping movements
- With drywall constructions, it is almost essential to measure the studs and screw directly into them instead of relying solely on the drywall surface
If possible, I would plan in advance what loads will be stored exactly and whether a potentially more robust custom-built wardrobe would be more suitable.
Ankeli
21 Jun 2024 10:01
I have always used expansion anchors in concrete walls for heavily loaded Pax units and secured them to the wall with brackets at the top. This holds very well. For drywall, it is essential to screw directly into the studs and not use regular hollow wall anchors.
RI-TAR
21 Jun 2024 11:39
Maria35 schrieb:
Use of heavy-duty anchors (e.g., Fischer UX or bolt anchors) suitable for the wall material (concrete, brick, drywall)
Thanks, that’s already quite specific. I’m particularly interested in the approach for drywall walls – how much can the load capacity be increased by attaching, for example, a multiplex panel or an OSB board to distribute the load? Are there recommended dimensions or minimum thicknesses to ensure the load is safely distributed?
GiRoyce
21 Jun 2024 13:07
The idea of using an OSB or plywood panel on drywall partitions is very effective. Important points to consider are:
- The panel should be at least 15 mm (0.6 inches) thick, ideally 18 mm (0.7 inches) or more
- The panel should be firmly screwed to the wall studs, preferably with at least 5-6 screws per stud
- The panel acts as a load-distributing surface so that the mounting points of the cabinet do not rest solely on the drywall
- Afterwards, the Pax cabinet can be attached to the panel using metal brackets instead of directly to the wall
- For heavy loads, this solution is often crucial because standard anchors in drywall are usually insufficient
This also improves stability against tipping and significantly increases the load-bearing capacity. If possible, it is recommended to create a reliable anchoring system for drywall partitions.
