I am currently planning to assemble an Ikea Pax wardrobe and am preparing for a somewhat more complex assembly project. Since I want to combine several modules and accessories, it would be great if you could share your tips and experiences regarding the assembly.
I am particularly interested in advice on:
- Preparation and tools
- Procedures for large wardrobes
- Common mistakes or pitfalls
- Tips for simplifying the assembly, such as assembling in parts
- Experiences with modifications or special requests for Pax
I look forward to practical tips, including recommendations on what to avoid.
Thank you in advance!
Hello roald,
I’d be happy to give you a structured guide for assembling the Pax wardrobe that covers almost all important points:
1. Preparation:
- Read through the entire manual before you start.
- Sort all parts by screws, wooden panels, etc., so you don’t lose anything.
- Tools: cordless drill with screwdriver bits, spirit level, rubber mallet, screwdriver.
2. Procedure:
- Assemble the individual modules separately first, so you have easy access to all screws.
- Align the modules using a spirit level, otherwise it will get complicated at the end.
- Only screw the modules together once each one is standing independently.
3. Common mistakes:
- Incorrect screw placement — check the screw torque and don’t run the drill at full power.
- Mixing up parts — take your time to compare them carefully.
- Not securing the wardrobe to the wall — the Pax can become unstable quickly.
4. Tips:
- Allow enough time (at least half a day for larger wardrobes).
- With multiple helpers: one can hold parts, the other can screw.
- For the floor: make sure it’s level — use small wedges to even it out.
5. Adjustments:
- Pax frame constructions are compatible; you can often experiment with dividers or interior fittings.
- When hanging doors: pay close attention to exact hinge spacing.
This should get you through smoothly. If you want, I can also go into detail on specific modules.
LOGEMIN
1. Preparation:
2. Procedure:
3. Common mistakes:
4. Tips:
5. Adjustments:
LOGEMIN
SETHBLA schrieb:
Make sure to secure the cabinet to the wallYes, absolutely! Otherwise, the small piece of furniture will become a wobbly tower, and I’m sure none of you are furniture yoga experts 😄.
Also, I recommend clearing enough space in advance and unpacking the boxes so you can start right away. And if you don’t have a cordless drill: take plenty of time to screw everything by hand. It takes longer, but you get a better feel for how tightly everything fits.
If you want extra storage on top, you can also cut shelves yourself for the Pax—this turns the cabinet into a super flexible piece.
LOGEMIN schrieb:
Do not fix the wardrobe directly to the wall – the Pax becomes unstable quickly.Thanks for the tip, that sounds very important. Are there any specific recommendations on how to best carry out the fixing? For example, the ideal distance from the wall, suitable anchors or screws?
SETHBLA schrieb:
Sort all screws and parts beforehandThat sounds reasonable, but I wonder if I should sort the parts exactly by their numbers or if it’s enough to separate screws, anchors, etc.?
loken schrieb:
If you want extra storage on top, you can also cut shelves yourself for the Pax – this turns the wardrobe into an ultra-flexible solution.That sounds interesting. Does anyone have experience on how to do this best without compromising stability?
roald schrieb:
Are there any specific recommendations on the best way to attach it? For example, what distance from the wall, suitable plugs or screws?Very good question. The cabinet should be fixed directly to the wall, usually leaving about one centimeter (0.4 inches) of space so that the back panel of the cabinet doesn’t press against the wall. Screws with universal anchors (8–10 mm (0.3–0.4 inches)) are sufficient, depending on the wall material (e.g., concrete, drywall).
I recommend at least two attachment points per cabinet module at eye level. For drywall, definitely use special hollow wall anchors to ensure stability; otherwise, it will be unstable.
roald schrieb:
Should I sort the parts exactly by numbers, or is it enough to separate screws, plugs, etc.?At a minimum, sort screws and wooden parts by type and length. Numbered sorting makes the most sense if you prepare the components for each assembly step in advance. Small boxes or bags for the screws work well for this. It saves a lot of time during assembly.
roald schrieb:
Does anyone have experience on the best way to do this without compromising stability?If you cut shelf boards yourself, it’s best to use a circular saw or an orbital sander to finish the edge neatly. Make sure the load-bearing capacity isn’t reduced—thin or too short shelves can bend over time. If necessary, reinforce them with additional supports or metal braces underneath the board.
