ᐅ Is there a way to completely disassemble an Ikea Pax wardrobe without leaving any damage or residue?
Created on: 15 Dec 2021 08:17
arend37
arend37
15 Dec 2021 08:17
Good morning everyone, over the past few days I have been trying to completely disassemble my Ikea Pax wardrobe in order to move it. Now I have the question: Is there a way to take apart the Ikea Pax wardrobe without leaving any damage, such as screw holes being affected, dowels breaking, or the material being compromised? I want to avoid any issues during reassembly or potential resale later on – does anyone know a reliable and proven method to disassemble the wardrobe so that it can be restored to its original condition without visible marks?
Layla
15 Dec 2021 09:02
Hello arend37, I completely understand that you want to disassemble the cabinet without causing any damage – I had a similar experience with a large Pax unit. In my experience, it works quite well if you’re patient and carefully loosen the screws step by step, especially those in the corner joints, which you should handle very gently. Sometimes small prying tools can help to gently separate the parts without widening the holes. However, with certain dowels, slight material wear is almost unavoidable, even with the greatest care.
Deandre
15 Dec 2021 09:35
Hello arend37, to answer your question as precisely as possible: The Ikea Pax system is modular and mainly uses flat dowels and metal fittings, which theoretically makes disassembly easier. The order of steps is important: you should completely remove all screws first, then gently tap or use a lever to release any tight fittings. Another key point is using a good screwdriver, preferably with a magnetic tip, to avoid damaging the screws. However, “without any residue” also means that sometimes the wood where the dowels were inserted shows slight discoloration – this cannot be fully removed with standard cleaning methods, so there will always be traces if you look closely.
nojaus
15 Dec 2021 10:07
I can also confirm from personal experience that dismantling the Pax is not easy if you want to do it without leaving any marks. You really have to work your way through the sequence step by step and quickly realize that simply following the assembly instructions in reverse order doesn’t always help. Above all, you need time and patience, and you should avoid using tools that are too large to prevent the wood from splitting. A small additional tip: When I reassembled it, some screws got slightly stuck, which ideally you want to avoid during disassembly by loosening everything thoroughly beforehand.
Genevieve
15 Dec 2021 11:15
I would like to briefly follow up and point out that the term “without any trace” is probably not entirely realistic in this context. Engineered wood materials, like those used by Ikea for Pax, always react mechanically to screw connections, especially with flat dowels and locking pins. Even if you remove the screws perfectly, visual marks such as small holes or dull spots will remain. This means a 100% restoration to the original condition without any traces is almost impossible. The question is: What is more important to you? Easy disassembly with normal marks or the best possible cosmetic result? Because when discussing the “possibility,” the definition of “without any trace” must also be considered.
arend37
15 Dec 2021 11:59
Genevieve schrieb:
This means that a 100% restoration to the original condition without any traces is almost impossible.
Thank you for the insight, Genevieve. That’s exactly what I want to find out – whether there are any tricks or special techniques to minimize traces. During disassembly, I’ve noticed that the corner joints and metal brackets with screws are particularly problematic. How do you handle the loose tenons that can be quite tight? Do you have to pry them out or pull them out? It would be great if someone has detailed experience with the disassembly process for the different types of connections.
