ᐅ How can a Pax wardrobe be reinforced?
Created on: 5 Nov 2022 19:23
Reoki
Hello everyone, I recently bought a Pax wardrobe from IKEA and have noticed that the structure feels a bit unstable under heavier loads. So, my question to the community is: how can a Pax wardrobe be reinforced, especially when loading it with many heavy clothes and boxes full of household items?
I am interested not only in simple solutions but also in which reinforcements make sense without compromising the design or making assembly more complicated. Which parts of the frame or the back panel are best suited to ensure extra stability? Are there any proven DIY tricks or additional accessories from IKEA or third-party manufacturers that you would recommend?
Looking forward to your experiences and tips!
CHENFAR
6 Nov 2022 10:29
My experience with Pax shows:
- The most important support is the back panel. By default, it consists of a thin particleboard fixed with nails, which provides little stability.
- Retrofitting a solid plywood panel (6-9 mm (0.24-0.35 inches)) with screws significantly increases torsional rigidity.
- Metal brackets in all corners of the cabinet frame greatly enhance stability.
- For long shelves, a cross brace (e.g., a wooden strip or metal profile underneath the shelf) is important to prevent sagging.
Equally important is proper installation: The screws should be correctly secured, and the cabinet must be placed on a level floor. Unevenness causes wobbling, which reduces load capacity.
Finally: Do not overload the shelves; instead, place heavy items near the bottom or distribute them evenly.
PAREL
6 Nov 2022 11:48
Reoki schrieb:
Which parts of the frame or back panel are best suited to ensure greater stability?
In response to this specific question:
- The first choice is the back panel, as it plays the biggest role in the rigidity of the cabinet.
- Second, the corner braces in the four corners provide the greatest benefit because they significantly strengthen the connections between the bottom, sides, and top panel.
- Additionally, I recommend installing metal profiles behind or beneath the shelves to increase their load capacity.
If door movement is an issue, reinforcements should be installed so they do not interfere with the door slides. Remove old nails or screws to avoid double fastenings.
A systematic approach to follow is: secure the back panel > install corner braces > add cross supports for the shelves.
sanjon
6 Nov 2022 13:02
If you want to stabilize the cabinet on site, attaching it to the wall can help. Additionally, adjustable feet provide support to prevent tipping.
LOJOPAR
7 Nov 2022 09:15
Hello everyone, I would like to add a step-by-step guide for reinforcing a PAX wardrobe that has proven to be very effective:
1. Check the back panel: Verify that the original back panel is firmly attached and covers the entire surface. If necessary, replace it with a plywood panel 6-8 mm (1/4–1/3 inch) thick.
2. Attach the back panel: Screw the back panel all around, not just with nails, to prevent warping.
3. Install metal brackets: Screw metal brackets into all four interior corners to reduce edge loads.
4. Reinforce the shelves: Place wide wooden battens or aluminum profiles underneath the shelves, ensuring they run along the entire length of the shelf.
5. Add a central support: For wardrobes wider than 100 cm (39 inches), install a central column or vertical post to further stabilize the base.
6. Check foot adjustment: Make sure all feet firmly stabilize the wardrobe, preventing any rocking movement.
This process significantly reduces cabinet deformation over time and extends the lifespan of your PAX wardrobe.
PLOMA
7 Nov 2022 10:41
faso31 schrieb:
By default, the PAX shelves are designed for a maximum load of 10-15 kg (22-33 lbs) – beyond that, it becomes critical.
Exactly, this brings me to another important point: it is often overlooked that the shelves in PAX wardrobes are attached using so-called Minifix connectors. These are not designed to support extremely heavy loads.
For a serious reinforcement, you can use custom-made shelf supports or panels that are fixed with through-bolts or even insert cross beams beneath the shelves. It is essential to measure precisely to ensure the doors do not get obstructed.
In general, the question arises whether it makes sense to load an IKEA PAX with very heavy weights or if an industrial-grade cabinet with a higher load capacity would be a more suitable choice.
