ᐅ How do I properly install Ikea PAX wardrobes in a corner?
Created on: 11 May 2018 18:37
kar47
kar47
11 May 2018 18:37
Hello everyone, I’m currently working on a project to install and align two Ikea Pax wardrobes in a corner of my bedroom. Unfortunately, mounting them in a room corner presents some challenges, especially regarding how to join the two wardrobes, align the doors, and fix them to walls made of different materials (drywall and concrete).
My questions are: How do I position the two Pax wardrobes correctly so that they fit flush into the corner without gaps between the wardrobes and the walls? What connection methods are recommended for the corner joint to ensure stability and even door spacing? Are there any specific tips for fixing to different types of walls?
I have general DIY skills but have only installed Pax wardrobes on flat walls before. Any detailed advice or a checklist would be greatly appreciated!
noge58
11 May 2018 18:52
Wow, great question! Installing the PAX system in a corner is definitely an exciting challenge. First of all, make sure the cabinets are positioned perfectly square to avoid any unsightly gaps. It’s best to use a spirit level and a protractor! 😊 For connecting the cabinets, I have always used the included corner connectors—they are sturdy and ensure everything stays firmly together. When it comes to the doors, it’s important to adjust the hinges correctly so they close flush. For different wall materials: use regular wall plugs for concrete walls, and for drywall, it’s better to use special cavity anchors. You’ve got this, good luck!
Hughno
11 May 2018 19:05
1. Make sure the cabinets are positioned at a right angle. 2. Use Ikea corner brackets for the connection. 3. Carefully adjust the door hinges according to the instructions. 4. For fastening: use concrete anchors for concrete, hollow wall anchors for drywall. Done.
pauPierce
11 May 2018 19:26
Installing PAX cabinets in a corner requires careful preparation and attention. First, you need to check the exact angle of the corner, as older or uneven walls often deviate from a perfect right angle – a precise angle gauge is helpful here. It is advisable to assemble each cabinet unit separately before connecting them, so you can properly secure the corner connectors between the side panels. A processing tolerance of a few millimeters can later result in uneven gaps between the cabinets. It’s best to align the doors only after the cabinets are positioned in their final place to avoid misalignment errors. When screwing the cabinets to the wall, consider the different wall materials. Classic nylon anchors are ideal for concrete or masonry walls, while hollow wall anchors should be used on drywall to ensure proper load-bearing capacity. A tip: use an acoustic level or digital spirit level for fine adjustments, and don’t forget to adjust the cabinet feet to compensate for uneven floors. What are the dimensions of the corner, and do both cabinets fit exactly, or do they need to be slightly offset?
kar47
11 May 2018 19:48
Thanks for the previous advice! The corner space measures exactly 185 x 185 cm (73 x 73 inches). I have two cabinets, each 100 cm (39 inches) wide and 60 cm (24 inches) deep. They are positioned at a right angle to each other, but the area is not perfectly level: the floor has a slight slope forward, and the walls are not completely smooth—concrete wall on the left and drywall behind on the right. I plan to place the right cabinet against the concrete wall and the left cabinet against the drywall. The door hinges appear to be adjustable, but I’m concerned that due to the differences in the walls, the cabinets might not align flush or could even wobble. That’s why I’m asking about a secure and stable way to connect the two. Should I really rely on the Ikea corner connectors, or would it be better to use my own brackets?
hauklo
11 May 2018 20:05
Basically, the Ikea corner connectors are sufficiently stable as long as the cabinets are installed precisely. For slight floor unevenness, I recommend leveling the cabinet legs using a spirit level and, if necessary, using shims. Regarding wall mounting: for concrete walls, use nylon anchors with screws of appropriate length—make sure they are embedded as deep as possible in the masonry. For drywall, cavity anchors or metal molly bolts are essential to ensure adequate load capacity. Since two different wall types meet at the corner, it is important to check that the cabinets are perfectly aligned before fastening. Ikea corner brackets are recommended for the connection angle between the cabinets, as they ensure correct positioning and prevent misalignment. Custom brackets can be used but are generally unnecessary and may cause gaps if installed inaccurately.
