ᐅ How can I make effective use of IKEA PLATSA in a child's bedroom?
Created on: 20 Apr 2016 18:09
pefar63Hello everyone, I am currently planning to furnish my two boys' bedroom with the IKEA PLATSA system and have some questions. Has anyone had experience using PLATSA units effectively, especially regarding storage space, flexible layout, and how to make it age-appropriate and safe? I am considering combining both open and closed sections because I need storage for toys, books, and clothes. It is also important for me to know the best way to secure the modules, as young children often tend to be quite rough with furniture. Any ideas, including lighting or accessories that fit well with the system, are very welcome. Thanks in advance!
pefar63 schrieb:
Does anyone have experience with how to effectively use PLATSA systems, especially regarding storage, flexible layout, and making it age-appropriate and safe?That’s a very good question, as PLATSA is indeed a versatile system but requires some planning to fully utilize its benefits in a child’s room. Generally, I recommend measuring the room precisely first and then considering what functions the furniture should fulfill:
- Clothing storage: Combinations of drawers and hanging rods at different heights are especially helpful. Hanging areas can be set lower, for example, so children can reach them independently.
- For toys, adjustable-height shelves are ideal. Whether open or with bins, this can be easily adapted.
- Safety: The system must be secured to the wall. IKEA provides special brackets for this. Additionally, I would recommend smoothing edges or adding soft edge protectors. This can save a lot of stress.
- Flexibility: PLATSA can be expanded gradually. For example, as the children grow, you can reposition shelves or add modules.
Using doors with soft-close features is also useful to prevent finger injuries.
A few questions for you: What is the room size, and how old are your boys? This helps tailor the setup better to their needs.
Noahlu schrieb:
You can expand PLATSA step by step. For example, as the children grow, you can rearrange the shelves or add modules.I can only confirm that. For us, it was always a priority to adapt to new needs. It’s also really useful to consider storage options for small items, like small baskets in the shelves.
Regarding your point about safety: we always securely fixed the units to the wall and chose doors without sharp edges. I like the mix of open and closed elements because it lets your child decide what they can easily reach, while larger items are safely stored.
I’m curious how you plan the space for a desk or play areas? That is often part of the setup too.
Noahlu schrieb:
A few questions for you: What is the size of the room and how old are your boys?Thanks for the detailed advice! The boys are 4 and 6 years old, and the room is about 12 square meters (130 square feet). It should have space for playing, studying, and sleeping – so a small desk module would also be useful. I think the system will probably be installed along one wall because of the size and to leave enough open space.
Regarding safety: I also want to childproof the edges and doors, you’re right about that, and I will secure the entire setup. However, I’m still interested in the best way to do this (for example, to ensure stability if it gets bumped hard). That is especially important with very young children.
pefar63 schrieb:
but exactly how to do this best (e.g., for stability, if it gets bumped hard)Here, wall mounting is really key, so don’t just use the small corner brackets that come with IKEA furniture. Instead, consider using additional anchors and angle profiles that support the entire width of the module. If the wall surface allows, use screws with appropriate anchors for solid walls.
Additionally, you can fix the modules together with connecting clips to prevent any shifting. For the edges, rubber or foam protective strips work well—especially on corners.
Regarding flexible use: also consider installing parts with a lower crossbar height. This makes it easier for children to reach and promotes independence and oversight.
The desk can be integrated as a separate element or designed as part of a half-height unit with open compartments underneath. Make sure to plan for good cable management and storage surfaces there.
