ᐅ How can I best install Ikea HEMNES on uneven floors?
Created on: 21 Oct 2019 08:13
anemeric
anemeric
21 Oct 2019 08:13
Hello everyone, I am planning to install my Ikea Hemnes wardrobe in my bedroom on a very uneven wooden floor. The unevenness is noticeable, causing the wardrobe to wobble slightly when placed directly without any adjustments. My question: What is the best way to install the Ikea Hemnes on uneven floors so that the piece of furniture stands securely and stably without developing damage or wobbling over time? Are there any suitable solutions for compensating unevenness that you have tested? I am open to practical tips, possible additions like pads or leveling feet, as well as advice on how to adjust the installation process generally or what to consider regarding the screws. I look forward to your experiences and recommendations.
Luke44
21 Oct 2019 09:02
I would recommend placing felt pads or furniture wedges under the legs to compensate for minor unevenness. For larger floor irregularities, adjustable furniture casters or specialized leveling feet are a good alternative.
roryvin
21 Oct 2019 09:45
Assembling Ikea HEMNES furniture on uneven floors requires targeted compensation for irregularities to ensure stability and avoid material stress. There are several options: - Adjustable furniture glides or adjustable leveling feet allow precise adaptation to the floor. These usually need to be purchased separately, as Ikea typically supplies standard furniture with fixed feet. - Alternatively, sturdy, narrow wooden wedges or rubber pads can be used to even out uneven surfaces. It is important to secure the wedges flush and firmly to prevent slipping. - During assembly, ensure that all connectors are fully and correctly tightened to avoid any stress in the structure. - In rare cases, it can help to locally level the floor before assembly, for example by sanding or applying a thin layer of leveling compound. However, this approach is more labor-intensive and should be carefully considered. In summary, purchasing adjustable furniture glides is usually the most effective and gentle method.
Mariah
21 Oct 2019 10:11
Hey, I also set up my HEMNES on a pretty uneven floor – and yes, it’s a challenge! But with a few tricks, it works great: I used small rubber pads, which you can stick under the legs. They not only reduce wobbling but also protect the floor. If the floor is really uneven, I used wooden shims – you can easily fix them in place with double-sided tape so nothing slips. And don’t worry, you don’t have to become a pro right away! By the way, once the cabinet is standing firmly, the whole room just feels much cozier 😊
Ramon4
21 Oct 2019 11:32
Hello! I think it is very important to carefully prepare the base for the HEMNES on uneven floors. First, you should check where the greatest unevenness is before assembly. This can be done quite easily with a spirit level or even a straight board placed across the feet.
If there are uneven spots, I recommend:
- Sanding or cutting adjustable furniture glides to size and attaching them under the feet. These allow for height-adjustable leveling.
- Alternatively, you can use custom-cut wooden wedges. It’s best to secure these with wood glue to prevent shifting.
- It is important not to simply place the cabinet on an uneven floor and hope it evens out, but to prepare the floor slightly in advance if possible.
- In some cases, a thin OSB board underneath the cabinet can help create a level surface. Then, adjust the feet accordingly so that the cabinet does not wobble.
- When assembling, make sure to tighten all screws and connections firmly to make the structure torsion-resistant.
If the floor is very uneven, I recommend the option with adjustable furniture glides—as in my experience, these are the most flexible and reliable solution. Also, they can be adjusted later if conditions change.
sarlo
21 Oct 2019 12:47
I would like to add that when assembling the HEMNES on uneven floors, special attention should be paid to the stresses caused by the construction. A wobbly cabinet can put pressure on the joints, which over time can damage the frame. Therefore, it is important to carefully and individually adjust all the feet. Here are some tips I have summarized: - Use a spirit level to determine the actual unevenness. - Adjustable furniture glides with threaded inserts are ideal because you can precisely adjust the height. These are not included in the Ikea set but can be purchased inexpensively. - If you use wooden wedges, make sure they are tall enough and securely fixed. Slippery wedges can make the problem worse. - If possible, you can use epoxy or repair filler to smooth out or fill small floor irregularities. - When assembling the HEMNES, do not forget that the back panel should only be inserted once the cabinet is stable, as it otherwise makes adjustments more difficult. In summary, a combination of mechanical adjustment of the feet and careful assembly helps.
