I am currently facing the challenge of assembling an IKEA Platsa wardrobe on a significantly uneven floor. Specifically, it is an older wooden floor with visible irregularities of about 1.5 to 2 cm per meter (0.6 to 0.8 inches per 3.3 feet), occurring both lengthwise and crosswise. I want to build the wardrobe as stable and durable as possible, without it wobbling or experiencing stress caused by uneven support surfaces.
My question is: What technical and practical approaches are recommended specifically for installing PLATSA systems on uneven floors? I am particularly interested in tips for leveling, anchoring, and preventing material strain due to slope. I would also appreciate suggestions for additional accessories or alternative installation methods suitable for this situation.
theota schrieb:
An alternative is to avoid installing the cabinet close to the floor and instead fix a support frame to the wall, then mount the PLATSA so it hangs from that frame. This suggestion is interesting, but I wonder if it is truly practical. Firstly, how can a sufficiently stable wall frame be constructed without losing the flexibility that PLATSA offers? Secondly, is the load on the wall safe to carry in an older building with possibly fragile masonry? Has anyone had experience with this? Additionally, such a wall frame does not seem compatible with the usual IKEA concept. The system is specifically designed for modular self-assembly. In my opinion, this creates a conflict between DIY and professional stability that is not easily resolved.
I understand the concerns and would like to add a practical note: For most residential applications, adjustable feet combined with a secure wall attachment are sufficient. Uneven floors can be compensated for by adding cross braces under the cabinet frame. For example, simple wooden slats or metal profiles can provide additional lateral and bottom support to the PLATSA frame. Installing an extra wall frame is only worthwhile for very heavy loads or highly uneven floors that cannot be leveled through simple adjustments. It is also important to carefully align the unit during assembly; using a spirit level and, if possible, a second person can significantly improve stability.
linavin schrieb:
Is the load on the wall in an older building with partially crumbly masonry even safely bearable? Regarding your concern: This is indeed a critical point. Choosing the right anchors and, if necessary, installing support battens behind the cabinet are decisive factors. For example, heavy-duty anchors can be used, or wooden battens can be fixed to the wall to better distribute the load.
I would also like to point out that when leveling unevenness, care must be taken not to introduce stress into the frame: each leg should be adjusted individually so that every point rests evenly on the floor. In my experience, it helps to assemble the cabinet first without the back panel and only attach it after alignment, preventing deformation of the frame.
