ᐅ What is the best way to clean IKEA PLATSA to remove dust?
Created on: 8 Sep 2017 09:12
Jolumau
Jolumau
8 Sep 2017 09:12
Hello everyone, I have been using the IKEA Platsa system at home for some time and am wondering about the best way to regularly remove dust from it. The surface is mostly white and seems quite sensitive to scratches or moisture. What cleaning methods or products are most suitable for gently removing dust without damaging the surface? I am especially interested in tips on preparation, recommended tools, and maintenance advice, as I want to keep the cabinet in good condition over the long term. Thanks in advance for your experiences and recommendations!
Meonu
8 Sep 2017 09:36
Hey Jolumau, your question fits perfectly with my experience. For dust on PLATSA, I usually use a microfiber cloth – very gentle and cleans effectively without scratching. Simply dry or slightly damp is usually enough. I completely avoid harsh cleaners; they are really unnecessary. And of course, regular dusting keeps the cabinet fresh. Sometimes I also use a small brush for corners to keep the dust from bothering me. It’s all very easy, no stress!
Tarmau
8 Sep 2017 10:05
As an addition: The PLATSA system is mostly made of coated wood-based panels with a smooth surface that can be sensitive to water and abrasive substances. For dust removal, a dry microfiber cloth or a duster is recommended. If moisture is necessary, use a lightly damp, soft cloth without any cleaning agents. Abrasive cleaners or harsh chemicals should be avoided as they can damage the surface. Regular, gentle cleaning will extend the lifespan of the furniture.
NOAHSAU
8 Sep 2017 10:29
Tarmau schrieb:
If moisture is necessary, a lightly damp, soft cloth without cleaning agents is recommended.
I would like to disagree here. Sure, using water in moderation is fine, but I believe you can actually clean such furniture effectively when dry. Dust is “dry,” so a good dry microfiber cloth should be completely sufficient. I doubt that the surface of PLATSA really requires moisture – I actually see more risk of creating white water stains or streaks if you’re not careful.
RON57
8 Sep 2017 10:53
Additionally, I would like to point out that avoiding direct contact with water is very important when cleaning IKEA PLATSA. I always make sure that the cloth is only slightly dampened. A soft, lint-free cloth is suitable for dusting. For hard-to-reach areas, cotton swabs or small brushes can be used. If heavier soiling occurs, I recommend using a mild dish soap diluted with water, but be sure to wipe it dry immediately to prevent damage.
silako
8 Sep 2017 11:19
I believe we should focus on verifiable facts here. Since PLATSA is made from melamine resin-coated particleboard, it is sensitive to solvents. I recommend avoiding any cleaning products that contain alcohol, ammonia, or abrasives. A slightly textured cloth or microfiber cloths with a neutral wood cleaner are completely sufficient. Important: Do not apply pressure, as this can damage the surface. Ideally, let the cleaning process take effect briefly on dust daily, so it remains simple.
