ᐅ Are there any tips for leveling Billy shelves on uneven floors?
Created on: 7 Nov 2021 08:23
flo_zarHello everyone, I have some Billy shelves from Ikea at home that I set up on a rather uneven floor. This causes the shelves to wobble slightly and not stand properly. Do you have any experience or tips on how to best level or stabilize Billy shelves on uneven floors? I am mainly looking for practical solutions that can be implemented without much effort or special tools. Thanks in advance!
Z
zarHenning7 Nov 2021 08:45Simply place washers or felt pads under the shelf feet. This is inexpensive and quick to do.
To properly level Billy shelves on uneven floors, I recommend a multi-step approach: First, use a spirit level to identify the exact uneven spots. Often, attaching small rubber pads or felt gliders to the shelf feet helps to compensate for minor irregularities and prevent scratches. For larger height differences, wooden wedges cut to size can be placed between the floor and the shelf base. It is important to secure these wedges—using adhesive, for example—to prevent them from slipping. It is also advisable to stabilize the shelf by fixing it to the wall to prevent it from tipping over when standing up. What type of flooring do you have exactly? Laminate, tiles, or perhaps parquet? On very soft floors, the weight might also make it harder to keep wedges pressed down.
lorena schrieb:
For larger height differences, wooden wedges cut to size can be placed between the floor and the shelf That sounds interesting, thank you! The floor is older tiled flooring with visible grout lines and small uneven spots, so it wobbles. You mean I should fix the wedges in place, otherwise they might slip, right? Can this be easily done with construction adhesive by myself? Are there other materials suitable for this? I don’t want to cause any damage to the floor.
