Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
haydee
15 Jul 2018 12:18
Only exterior roller shutters on all four sides
11ant15 Jul 2018 15:54
Climbee schrieb:
However, no external roller shutters
At least considering this idea can be quite obvious with ETICS / cavity wall construction. This could actually lead to a "revival" of this option.
Müllerin
15 Jul 2018 16:49
We mainly wanted this because it provides easy access when working on something, because no renovations inside the room are needed afterward, because there is no passage to the interior, meaning no animals can get through. And also because we like how it looks.
Alex85
15 Jul 2018 17:07
I think your setup actually looks pretty good.
In general, for new builds, I would lean towards using surface-mounted boxes. They work with any type of construction, as long as the window isn’t floor-to-ceiling. Plus, an external or bottom access panel allows for maintenance without causing damage, even if it’s a bit tricky.
My "why?" question was actually directed at @11ant.
matte
15 Jul 2018 17:13
Climbee schrieb:
We will do the same. However, no exterior roller shutters
Do you mean the roller shutters outside the window or the surface-mounted cassette box?
By interior roller shutters, I would understand shutters that are lowered inside the room.
That would be quite unusual and especially disadvantageous for heat protection...
So I actually can’t imagine that.
11ant15 Jul 2018 17:23
matte1987 schrieb:
Do you mean the exterior roller shutter in front of the window or the surface-mounted box?
As you can see in the picture, they probably mean exterior roller shutter boxes.
You would be right that having blinds behind the glass would be pointless for heat protection.
Alex85 schrieb:
My "why?" referred to @11ant.
Because—at least if you choose the rounded version—the roller shutter box can be installed completely outside the structural wall layer. That might make some homeowners consider this originally "modernization option" for new construction.
