ᐅ Malm bed squeaks when moved on uneven floors – any solutions?
Created on: 13 May 2023 19:23
Royan
Royan
13 May 2023 19:23
I have been using an IKEA Malm bed for some time now, which is generally very sturdy. However, when moving, especially if the floor under the bed is uneven, it often produces an annoying creaking noise that is quite disruptive. I have already tried rebuilding the bed and using different types of underlays, but the problem persists.
My question is:
How can I permanently fix the creaking noise on my Malm bed, particularly when it occurs on uneven flooring? Are there practical solutions or proven tips to prevent these noises caused by movement?
If you have experience with Malm beds or similar models, I would appreciate detailed advice! Thanks in advance.
Surela
13 May 2023 19:57
Hello Royan,
I can understand your problem well because a squeaking bed is not only annoying but can also put stress on the materials over time. The Malm has a relatively simple construction, consisting of wooden panels and screw connections, which is generally sturdy but can be challenging on uneven floors.
First of all, it is important to identify exactly where the squeaking is coming from. Often it is the screws that have loosened slightly or the joints between the side panels and the cross slats. When the bed is loaded and moves, the materials shift slightly, causing friction noises.
A first step is to tighten all screws with an appropriate Allen key or Phillips screwdriver. Be careful not to overtighten, as this can damage the wood, but also avoid leaving them too loose.
Then I would recommend treating the contact surfaces between wood and wood, especially on the slats, with a dry lubricant like talcum powder or beeswax. Avoid oils or grease, as they can damage the wood surface.
On uneven floors, placing something under the bed legs can help, such as small furniture pads with felt, which can compensate for unevenness somewhat and provide better cushioning. Have you tried adding rubber pads? These can reduce friction and minimize noise.
And basically: sometimes it helps to check the bed base itself — whether the slatted frame support is firmly seated and has no play that could cause movement.
Finally, I wonder how severe the floor unevenness is. Even a slight movement can cause larger shifts in the bed, especially if it rests on only four points.
Could you describe how your floor is exactly? Are these actual irregularities or rather slight variations? And what kind of material is underneath?
theo63
13 May 2023 20:15
Interesting approach from @Surela
However, I would also try to look at the cause from a different perspective: Could it be that the floor is just a symptom and the actual problem lies within the construction of the bed itself?
Some time ago, I bought a Malm bed myself and noticed that the joints between the headboard, footboard, and side panels have some slight play due to the metal brackets when moved. This can become more pronounced under load on an uneven surface.
So my question to Royan: Is it possible for you to check the fastening elements again to ensure they are firmly secured or even reinforce them with stronger brackets and screws?
You could also try placing a solid base completely under the bed as a test, for example a large board that levels the floor. If this helps significantly, you could then focus the solution more precisely.
@Surela also mentioned dry lubricants, which I like, but caution: There are reports that some products cause wood fibers to swell and worsen the fit.
My tip: Also check the joints with assembly adhesive or special wood connectors if you are not considering a return.
V
Vinlen
13 May 2023 20:44
Brief and to the point:
One of the most common causes of squeaking noises from beds on uneven floors is the lack of flexibility in the adjustable feet, leading to movement of the entire frame.
My recommendations:
1. Attach small self-adhesive foam pads under the feet. These compensate for unevenness and prevent direct friction on the floor.
2. Check all screw connections, as mentioned before, to ensure they are tight.
3. If you are using a slatted frame, verify that it fits flush and does not slip, as this can also cause noise.
4. Alternatively, you can glue vibration-damping blocks (e.g., small rubber buffers) between the contact points of the slatted frame support and the frame.
This usually helps effectively and prevents screw connections from loosening over time.
Are there specific areas where the squeaking is especially loud? More towards the foot area, head area, or on the sides?
Fitigu
14 May 2023 09:07
Accurate diagnosis of the noise source is essential.
A common cause in flat-pack furniture, such as the Malm bed from IKEA, is a combination of slight movements between wooden panels and uneven load distribution on an irregular floor.
The following solutions are practically recommended:
1. Systematically tighten screws without over-tightening.
2. Lightly sand wooden joints at the edges if they are too tightly fitted together to reduce friction points.
3. Apply cushioning materials such as felt pads under the legs. These absorb movement.
4. Inspect the floor for significant unevenness and, if necessary, treat it with leveling compound or place a stable underlay.
A combination of these measures will sustainably minimize the problem.
As a rule, lubricants are counterproductive since they attract dust and wood particles, which worsens the effect over time.
brianna
14 May 2023 09:46
Royan schrieb:
How can I permanently stop the squeaking of my Malm bed, which mostly happens on uneven floors? Are there practical solutions or proven tips to prevent these noises when moving?
I think this topic is really important because a bed is supposed to be a place of relaxation, and constant squeaking can really disrupt that.
I had a similar issue, and what helped me was trying out different materials between the bed legs and the floor. In the end, I used special felt furniture pads – these not only significantly reduce noise but also stabilize the bed on slightly uneven floors.
I also made sure to regularly check the screws and occasionally move the bed slightly to see if anything was loose.
It does take a bit of time, but it’s worth it to be able to sleep peacefully.
