ᐅ Are there specially reinforced replacement parts available for Malm?
Created on: 16 Apr 2016 07:47
U
Urs53
Good morning everyone,
I am currently looking for replacement parts for the IKEA Malm bed. I was wondering if there are specially reinforced replacement parts for the Malm series that go beyond the standard original components. I mean things like strengthened bed rails, additional cross supports, or more durable screws and fasteners to significantly improve durability and stability.
Does anyone know of suppliers or solutions that manufacture or sell specially optimized or reinforced replacement parts for the Malm bed? Or at least recommendations on where to find high-quality alternatives that are better than the standard materials?
I understand that many people use the original parts, but especially with heavier use or more intense daily wear (for example, two people using the bed extensively every day), I am interested in ideas for stronger versions or upgrades. Thanks in advance for your tips and suggestions!
ronAlberto16 Apr 2016 11:37Hello everyone,
I would like to go into more technical detail here, as the question about specially reinforced replacement parts for the Malm bed is somewhat more complex.
The Malm bed is mainly made from coated wood-based panels and is built on a carcass system held together by simple connectors. Its stability primarily depends on the connection points and the load distribution on the cross slats.
Original replacement parts from IKEA are cost-effective and designed for the intended loads. I am not aware of any specially reinforced or optimized replacement parts offered by the manufacturer, which is rather uncommon for IKEA.
If you want to increase stability, it is advisable to target the weak points specifically:
1. Cross slats: Replace with solid wood or metal profiles, which can be fixed with suitable fasteners.
2. Fastening elements: Stainless steel screws or ones with a higher strength grade, possibly larger in size as long as the material allows.
3. Metal reinforcement brackets at the corners and support points to prevent slipping and twisting.
However, you should be aware that such modifications may void IKEA’s warranty. Also, the effort required for modifications that last long-term is not insignificant.
Could you please explain more precisely what issue you want to improve? Load capacity, creaking, crossbeam breakage? Then I can offer more targeted advice.
ronAlberto schrieb:
Could you please explain more precisely which specific issue you are trying to improve? Load, creaking, crossbeam breakage?Thank you for the detailed response! Basically, over the years I have noticed that the side panels of my Malm bed, and especially the joint between the bed sides and the cross supports, have noticeably lost stability.
That’s why I’m asking about reinforced replacement parts, as I would like to buy original parts and somehow strengthen them without having to replace the entire piece of furniture. The creaking is not yet the main issue; it’s more the gradual instability after years of daily use by two adults.
I think reinforced cross supports and possibly stronger screws or brackets could help. That’s why I’m asking about specific accessories that might be optimized for Malm but are not from IKEA.
Hello Urs53,
I had a similar problem and couldn’t find any specially reinforced replacement parts either. So, I simply screwed strong metal brackets at the joints, which made the bed significantly more stable overall.
Sometimes small DIY adjustments are more effective than expensive specialized parts.
Maybe this helps as a practical solution for you.
One additional note:
If you want to make the Malm bed more stable in the long term, it is worthwhile to distribute the load evenly.
It also helps to ensure that the slatted frame and mattress provide optimal support. Slatted frames with central zone reinforcement can further improve stability.
Additionally, I would recommend checking all screws and joints and replacing them with high-quality screws if necessary. Common stainless steel screws are often more durable.
Urs53 schrieb:
The gradual instability after years of use by two adults
benonon schrieb:
Slatted bed bases with central zone reinforcement can additionally help optimize support.Sure, but then the problem becomes obvious again: trying to get more stability out of cheaply made materials through various tricks instead of using durable constructions from the start.
IKEA tends to produce more disposable and replaceable furniture. Ideally, there wouldn’t be such long discussions if properly designed components were offered.
