ᐅ Why is my Malm bedside table squeaking?
Created on: 22 Dec 2021 09:13
Kinge6
Kinge6
22 Dec 2021 09:13
Some time ago, I bought a Malm bedside table from Ikea, but unfortunately, it keeps squeaking whenever I shake or move it. This is especially annoying at night when it’s quiet. I’m mainly interested in understanding why this squeaking occurs, even though the bedside table seems quite sturdy. Is it related to the construction, or could it be due to material fatigue? Is there a simple way to stop the squeaking without having to completely disassemble the bedside table? I would appreciate detailed and helpful explanations, as I would like to solve this problem permanently. Thank you in advance!
LOJOPAR
22 Dec 2021 09:46
Hello Kinge6,
Your question about the squeaking of the Malm nightstand is very well put and shows that you have an understanding of technical connections. The squeaking usually occurs due to friction between moving parts or loose joints that shift slightly under load.
Here is a structured overview of possible causes:
1. Check the screws: Are all screws and fasteners still tight? They often loosen slightly, which causes noise.
2. Locate friction points: Small irregularities or wood dust at the joints or on the wood can act like an abrasive.
3. Material fatigue: Under heavy use, wooden joints can swell or come loose, which creates noise.
Tip: Applying some wax (e.g., beeswax) or a special furniture oil at the joints can reduce friction and stop the squeaking. Be careful not to use oils that are too liquid, as they can damage the wood over time.
I hope this helps you!
retau
22 Dec 2021 10:05
That’s great that you analyzed the problem so thoroughly, Kinge6! 🙂
I once had a Malm nightstand that kept squeaking until I sprayed silicone lubricant on the hinges and joints. After that, it was quiet, and the nightstand worked perfectly again. Give it a try—it doesn’t cost much and often works wonders!
Good luck!
gasidney
22 Dec 2021 10:23
Squeaking usually occurs due to friction. Tightening screws, lubricating, or using wax almost always helps.
SETHBLA
22 Dec 2021 11:12
If the drawers are squeaking, check whether the drawer slides are properly installed. Often, adjusting them or applying a bit of lubricant is enough.
Davebla
22 Dec 2021 13:47
LOJOPAR schrieb:
Friction between moving parts or loose connections
That is basically correct, but I think it is important to consider whether the squeaking might also be caused by low-quality materials or design flaws. IKEA furniture is often produced cost-effectively, which can sometimes result in reduced durability.
Question: How old is your nightstand exactly? And have there been any visible signs of wear? This information can help us narrow down the cause.
