Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
dome2731 Jan 2019 13:22
Well, that would have to be quite a large—or tall—cabinet, and so far, this wall wasn’t really planned for that.
We’ll find a visually appealing solution; it can’t be that difficult.
Snowy36
31 Jan 2019 13:34
Exactly, that's how we do it as well (with the maintenance hatch in the hallway where the underfloor heating branches off – it’s a flush-mounted, baked enamel steel hatch, but something like that could also be installed here).
Would you have a picture of that?
Maria16
31 Jan 2019 13:37
Depending on the exact location of the fireplace, you could fill the wall with a faux wood shelf: attach wooden pieces a few cm (inches) long to a wooden board from behind and place it inside. Alternatively, a built-in shelf for some decoration that can be pulled out when needed?
Bookstar
31 Jan 2019 18:41
Why not from the outside? That’s how we solved it. Or do you not have a basement?
The chimney sweep will carry all the dirt inside like that, and the niche doesn’t look nice either.
dome2731 Jan 2019 19:17
No, we do not have a basement.
Z
Zaba12
1 Feb 2019 08:59
The RAL installation of the windows on the ground floor is complete, and the ceiling of the upper floor is insulated.
Metal windows in brick construction; reflecting a row of houses in sunshine.
White door frame with yellow painter’s tape; next to brick wall, rough plaster, and visible door hinge.
White window frame in a shell construction wall made of brick; debris on the floor.
Wood frame opening in wall with blue painter’s tape, OSB boards and metal supports
