ᐅ How do you replace the hinge on a Pax wardrobe?
Created on: 5 Jul 2015 14:02
U
Usgabriel
U
Usgabriel
5 Jul 2015 14:02
Hello everyone, I noticed that the right door hinge on my Pax wardrobe is loose and damaged. Since the door no longer closes properly, I want to replace the hinge completely. Could someone provide a detailed guide on how to professionally change the hinge on the Pax wardrobe? I am especially interested in the necessary tools, the disassembly steps, and any important tips to ensure the door fits well and functions correctly afterward. Are there any specific things to watch out for when removing and installing the hinge? Thanks in advance for your support!
Rashadmeo
5 Jul 2015 14:17
Great that you described the problem so precisely! Replacing the hinge on the Pax wardrobe isn’t that difficult if you know the right steps. You’ll need a Phillips screwdriver, maybe a small flathead screwdriver for prying, and of course the replacement hinge set. It’s important to remove the door beforehand so you can work more comfortably. If you want, I can provide you with a step-by-step guide! Don’t get discouraged—you’ll manage it really well! 🙂
Guyju
5 Jul 2015 14:29
Here is a step-by-step guide for replacing the Pax door hinge:
- Fully open the door and remove it from the frame. Usually, the hinges are attached to the door frame with a small lever or clip.
- Remove the screws from the damaged hinge using a Phillips screwdriver.
- Take off the old hinge and position the new hinge accurately.
- Tighten the screws again, making sure everything is properly aligned.
- Rehang the door on the cabinet and check the alignment.
Tip: After rehanging, the door should not stick. If needed, you can slightly adjust the hinges.
JONKO
5 Jul 2015 14:45
Guyju schrieb:
Tip: The door should not stick after being hung; if needed, the hinges can be slightly adjusted.
This is exactly the point I want to emphasize! I initially had trouble aligning the door. It was a bit frustrating at first, but with some patience and fine tuning, everything worked out great. If you like, I can also share my experience with the different types of hinges used on the Pax.
Fareo65
5 Jul 2015 15:03
For replacing the hinges, I recommend the following approach:
- Use high-quality screwdrivers to avoid stripping the screws.
- Start by detaching the door from the cabinet to allow unhindered removal of the hinges.
- The hinges are usually secured with 4 screws; all of them need to be removed.
- When installing the new hinge, ensure it is correctly aligned; otherwise, it may cause malfunctions.
The included assembly instructions from Ikea also provide helpful guidance and often show useful installation steps.
KOLAU
5 Jul 2015 15:19
Remove the door, unscrew the old hinge screws, attach the new hinge, tighten the screws, hang the door, and adjust if necessary. Done.
