Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
bortel
22 Jan 2019 14:10
Strange that many see it differently, but you are probably right.
Lumpi_LE
22 Jan 2019 15:08
Who would think otherwise?
I've never heard of placing a bathtub directly on the screed. It also doesn't make sense to install underfloor heating beneath it in a styrofoam block. Instead, you use supports, allowing the underfloor heating to run underneath the tub, although the tub would still stand on the raw ceiling.
MayrCh
22 Jan 2019 15:09
I think "many" is a bit of an exaggeration. A shower base directly on the raw subfloor is common practice in single-family houses. The screed settles under load, which then causes partial-elastic joints to crack. Not to mention the low entry height.
Z
Zaba12
22 Jan 2019 16:26
View times two
New construction site: Interior with large glass sliding doors, construction timber, brick walls, view to the outside.
blaupuma30 Jan 2019 19:02
It continues.
The screed has been poured...
Finally, you get a real sense of the room dimensions and ceiling heights... wonderful.
Unfinished interior with concrete floor, tangled cables, heating device, and large windows.
Unfinished interior with raw concrete walls, exposed ceiling, glass door, and blue handle.
dome2731 Jan 2019 07:38
Here is a brief update from me as well.
Over the past two weeks, the underfloor heating was installed and the screed was poured. Now, it needs to air-dry for two weeks, followed by a further two to three weeks of gradual heating.
Underfloor heating: heating pipes laid in loops on insulation layer indoors.
New dark gray floor; white walls, blue painter's tape on baseboards, left wall niche with metal panel
Unfinished renovation room: gray floor, sanitary fixture on the left, window on the right.
