annab377 schrieb:
At first, I thought that was a base for the washing machine. Why a separate foundation for the heat pump?I’m curious about that too. I’ve never seen a separate foundation for it. Isn’t it usually just placed later on the finished floor covering, after the screed?Bookstar schrieb:
I’m curious about that too. I’ve never seen a separate foundation for that. Normally, it just goes on top of the finished floor covering, after the screed, right?No, here it’s also decoupled from the screed to prevent vibrations from being transmitted. It definitely makes sense.benediktr schrieb:
Looks good. But two questions: Will the precast concrete ceiling remain unfinished? The clearance between the network cabinet and the door looks quite tight to fit a door frame, or is that just an illusion?The door frame requires 3.5cm (1.4 inches), and I have 5.5cm (2.2 inches) clearance. It should fit. The ceiling will be skim coated and painted. The painter said it’s no problem for the small area above the cabinet.
benediktr25 Oct 2020 20:39Bookstar schrieb:
That’s something I’m curious about as well. I’ve never seen a separate foundation for that. Normally, it’s just installed later on top of the finished floor covering, after the screed, right? Since the underfloor heating is installed before the screed and I didn’t want to pour screed over the entire room in advance, I made the foundation. This way, everything can be installed, the underfloor heating laid, and then everything is already prepared.
- Previous
- 1
- 2
- 3
- 10
- 20
- 30
- 40
- 50
- 60
- 70
- 80
- 90
- 100
- 110
- 120
- 130
- 140
- 150
- 160
- 170
- 180
- 190
- 200
- 210
- 220
- 230
- 240
- 250
- 260
- 270
- 280
- 290
- 300
- 310
- 320
- 330
- 340
- 350
- 360
- 370
- 380
- 390
- 400
- 410
- 420
- 430
- 440
- 450
- 460
- 470
- 480
- 490
- 500
- 510
- 520
- 530
- 540
- 550
- 560
- 570
- 580
- 590
- 600
- 610
- 620
- 630
- 640
- 650
- 660
- 670
- 680
- 690
- 700
- 710
- 720
- 730
- 740
- 750
- 760
- 770
- 780
- 790
- 800
- 810
- 820
- 830
- 840
- 850
- 860
- 870
- 880
- 890
- 900
- 910
- 920
- 930
- 940
- 950
- 960
- 970
- 980
- 990
- 1000
- 1010
- 1020
- 1030
- 1040
- 1050
- 1060
- 1070
- 1080
- 1090
- 1100
- 1110
- 1120
- 1130
- 1140
- 1150
- 1160
- 1170
- 1180
- 1190
- 1200
- 1210
- 1220
- 1230
- 1240
- 1250
- 1260
- 1270
- 1280
- 1290
- 1300
- 1310
- 1320
- 1330
- 1340
- 1350
- 1360
- 1370
- 1380
- 1390
- 1400
- 1410
- 1420
- 1430
- 1440
- 1450
- 1460
- 1470
- 1480
- 1490
- 1500
- 1510
- 1520
- 1530
- 1540
- 1550
- 1560
- 1566
- 1567
- 1568
- 1569
- 1570
- 1571
- 1572
- 1573
- 1574
- 1575
- 1576
- 1580
- 1590
- 1600
- 1610
- 1620
- 1630
- 1640
- 1650
- 1660
- 1670
- 1680
- 1690
- 1700
- 1710
- 1720
- 1730
- 1740
- 1750
- 1760
- 1770
- 1780
- 1790
- 1800
- 1810
- 1820
- 1830
- 1840
- 1850
- 1860
- 1870
- 1880
- 1890
- 1900
- 1910
- 1920
- 1930
- 1940
- 1950
- 1960
- 1970
- 1980
- 1981
- 1982
- 1983
- Next
