ᐅ Choosing a Foundation for a Garden Shed – Which Is the Most Affordable?
Created on: 11 Sep 2018 21:57
GelbesT
I am currently planning the foundation for a garden house, but there are so many different options: strip foundation, slab foundation, and so on.
The garden house will be a Karibu Eco Limburg 5.
Which is the most affordable (suitable) foundation for this type of garden house?
Kaspatoo schrieb:
I just googled "foundation for garden shed."
There are a lot of results. Right away, three videos from Bauhaus are suggested about different foundation types (concrete, slabs).That’s exactly why I’m asking here, because none of them explain which foundation is suitable for what!
I would first recommend checking the zoning plan to see if a foundation for a garden shed is allowed; here, it is not allowed... There is no mention of that in the zoning plan, but I have read similar things in forums. Does it have to be explicitly stated in the zoning plan?
nordanney12 Sep 2018 18:14What kind of building are we actually talking about? Perhaps it’s a small shed that can be placed directly on the lawn, or a larger, livable garden house that might require a concrete foundation.
When I look at the Google search mentioned above, there are also numerous websites,
for example, holzprofi24.
“Whether a foundation is necessary and which type is suitable for your garden shed depends on its construction, the soil conditions, and the intended use of the building, which may require a water or electrical connection.”
If that’s not exactly what you are looking for, there are certainly many more sites with additional information.
If you let us know how large your garden shed will be and which construction method you plan to use, some people here might be able to help you put that into perspective.
- Small tool sheds can basically also be built on compacted soil. However, especially with loose ground, it is advisable to use a layer of compacted gravel or sand as a base. This provides stability and helps with drainage after rainfall.
- Lightweight garden buildings constructed with a post-and-beam frame can be founded using so-called driven ground sleeves. The metal sleeves are driven into the ground using a sledgehammer, and the posts of the shed are then anchored in them.
- Larger and heavier garden houses, on the other hand, always require a foundation to compensate for ground movement. Various foundation types are available for different building styles.
nordanney13 Sep 2018 10:57GelbesT schrieb:
Thanks in advance. As I mentioned above, it will be the Limburg 5 garden shed. Sorry, I missed that.So it is basically just a traditional garden shed for storage.
Therefore, no real foundation is needed. Just some compacted gravel, a few paving slabs on top (you could probably even place them directly on the existing ground), and then build the shed.
