Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
HausiKlausi16 Nov 2022 22:22
borderpuschl schrieb:
We have a dishwasher like that too, but it only opens automatically in the Eco program.
Since I saw that comment, I’ve been thinking about it, but I can’t figure out: WHAT EXACTLY is the purpose of a dishwasher that opens by itself!? Of course, the Eco program dries faster because of the lower temperatures. But it does that for us as well with the door closed.
Alessandro
17 Nov 2022 07:47
HausiKlausi schrieb:
I’ve been thinking about this since that post, but I can’t figure it out: WHAT EXACTLY IS THE PURPOSE of a dishwasher that opens by itself!? Sure, Eco mode dries faster due to the lower temperatures. But it does that with the door closed in our case as well.
The quick drying and release of water vapor is the only reason.
If installed incorrectly, the door becomes a hazard.
At my brother’s place, the door slams down so hard that they have to put a cushion underneath.
Baranej
17 Nov 2022 08:20
Alessandro schrieb:
The fast drying and escape of water vapor is the only reason.
If installed incorrectly, the flap becomes a deadly hazard.
At my brother’s place, it hits the floor so hard that they have to put a cushion underneath.
Normally, it only opens a small gap, so it would never reach the floor. At least that’s how it works with our dishwasher, which I find quite practical. If you run it while at home, you can put the dishes away completely dry afterward. It’s a gimmick and not essential, but why not 😀
Winniefred17 Nov 2022 08:22
Our new Siemens dishwasher only opens a little bit automatically. I find that very practical as it saves energy. One from AEG, which we recently bought for someone, works the same way.
Alessandro
17 Nov 2022 08:28
It was only supposed to open a crack. However, if the kitchen fitter installs the wrong hinges, the door will swing open completely and crash to the floor, potentially damaging everything underneath :p
ateliersiegel17 Nov 2022 08:39
We also have a dishwasher with a "opening brake" (I didn’t even know there were models where the door doesn’t open slightly by itself). The lock is located in a plastic strip that slides out about 10cm (4 inches) when the washing cycle finishes and the dishes need to dry. To fully open the door, you then push it upwards and can move the door downwards. (Our door also has no special covering that might make it too heavy.) (This "single-step opening mechanism" can’t simply be pulled out for a photo. It only seems to reveal itself voluntarily after the work is done.)
