Lumpi_LE schrieb:
It looks like someone made a miscalculation; the numbers don't make sense. But that doesn't really matter for the document.
You can check in a year, if you still remember, to see what you actually consumed. Which specific value do you think the energy consultant miscalculated?
I know all the U-values of the individual building components, so the heat transfer coefficient (Ht) is correct. The primary energy indicator is also accurate. I know what technology I have installed.
Whether the actual energy demand will match the estimate, I cannot judge. I will see that in time. The photovoltaic system will offset a lot, as will the controlled mechanical ventilation with ground heat exchanger (if passive ventilation is applied consistently).
hampshire2 Aug 2019 08:42Yosan schrieb:
May I ask where you sourced the wood? We want something very similar and are currently looking around.On a classifieds site like Ebay Kleinanzeigen, there is apparently a part-time reclaimed wood dealer near Aachen (in Belgium) named Kris Wood. We took this piece experimentally on one of our “exploration trips.” It is oak wood. I sanded it and treated it with a brass brush to highlight the texture more clearly, then applied a glaze finish, followed by cutting and fitting it.H
hampshire2 Aug 2019 08:55The mirror will be frameless and very simple. The room is quite small, measuring 1.24 x 1.44 meters (4.1 x 4.7 feet). The mirror is intended to visually enlarge the space slightly. The ceiling lighting will be a backlit stretch ceiling with an image – this creatively opens up the room upwards. Pictures will follow once everything is completed.
- Previous
- 1
- 2
- 3
- 10
- 20
- 30
- 40
- 50
- 60
- 70
- 80
- 90
- 100
- 110
- 120
- 130
- 140
- 150
- 160
- 170
- 180
- 190
- 200
- 210
- 220
- 230
- 240
- 250
- 260
- 270
- 280
- 290
- 300
- 310
- 320
- 330
- 340
- 350
- 360
- 370
- 380
- 390
- 400
- 410
- 420
- 430
- 440
- 450
- 460
- 470
- 480
- 490
- 500
- 510
- 520
- 530
- 540
- 550
- 560
- 570
- 580
- 590
- 600
- 610
- 620
- 630
- 640
- 650
- 660
- 670
- 680
- 690
- 700
- 710
- 720
- 730
- 740
- 750
- 760
- 770
- 780
- 790
- 800
- 810
- 820
- 830
- 840
- 850
- 860
- 870
- 880
- 890
- 900
- 910
- 920
- 930
- 940
- 950
- 960
- 970
- 980
- 990
- 1000
- 1010
- 1020
- 1030
- 1040
- 1050
- 1060
- 1063
- 1064
- 1065
- 1066
- 1067
- 1068
- 1069
- 1070
- 1071
- 1072
- 1073
- 1080
- 1090
- 1100
- 1110
- 1120
- 1130
- 1140
- 1150
- 1160
- 1170
- 1180
- 1190
- 1200
- 1210
- 1220
- 1230
- 1240
- 1250
- 1260
- 1270
- 1280
- 1290
- 1300
- 1310
- 1320
- 1330
- 1340
- 1350
- 1360
- 1370
- 1380
- 1390
- 1400
- 1410
- 1420
- 1430
- 1440
- 1450
- 1460
- 1470
- 1480
- 1490
- 1500
- 1510
- 1520
- 1530
- 1540
- 1550
- 1560
- 1570
- 1580
- 1590
- 1600
- 1610
- 1620
- 1630
- 1640
- 1650
- 1660
- 1670
- 1680
- 1690
- 1700
- 1710
- 1720
- 1730
- 1740
- 1750
- 1760
- 1770
- 1780
- 1790
- 1800
- 1810
- 1820
- 1830
- 1840
- 1850
- 1860
- 1870
- 1880
- 1890
- 1900
- 1910
- 1920
- 1930
- 1940
- 1950
- 1960
- 1970
- 1980
- 1981
- 1982
- 1983
- Next
