ᐅ Is Wood Suitable for Building a Garden Shed?
Created on: 23 Jan 2009 07:55
Lily
Lily
23 Jan 2009 07:55
Good day,
I would like to have a small shed in my garden to store my furniture and equipment. Is it sufficient if it is made of wood, or should it at least be partially built with masonry?
Thank you
Hemd
Honigkuchen
23 Jan 2009 08:30
Hemd schrieb:
I would like a small shed in my garden to store my furniture and equipment. Is it sufficient for it to be made of wood, or should it at least be partly built with masonry?
Thank you
Hemd
Hello Hemd, I’m not an expert yet, but I can tell you two things for sure:
1. You ALWAYS need a solid, level foundation underneath, such as concrete; firstly, to prevent the shed from sinking, and secondly, to keep the inside from becoming muddy and damaging your shoes, stored equipment, and especially your furniture.
2. There is wood that rots easily and wood that can withstand wind and weather — especially since regular maintenance like repainting is necessary anyway.
There are also tool sheds made from metal, plastic, or glass.
I would choose the material based on the primary purpose of the shed: Will you mainly store garden tools, or do you want it to be more of a cozy tea pavilion, for example?
Depending on that, you select the material, shape, and size.
You should know from the start that it has to be weatherproof and remain so, so pay attention to quality when buying and ask what maintenance is needed to keep the weather resistance (care instructions and so on).
Unfortunately, I can’t say much more, as I have no personal experience, just what I’ve read so far. Hopefully, someone else will reply to you.
Honigkuchen
Lily
23 Jan 2009 12:41
I completely agree with Honigkuchen’s opinion. If you only want to store your equipment inside, wood is absolutely sufficient. My parents also enjoy sitting in there in the evenings; they have electricity and a small stove installed as well.
Best regards, Fondue
Lily
23 Jan 2009 13:12
Hemd schrieb:
Good day,
I would like to have a small shed in my garden where I can store my furniture and tools. Is it sufficient if it is made of wood, or should it at least partly be built with masonry?
Thanks
Hemd
Hi,
my neighbor built his out of reclaimed wood, but he poured a concrete foundation because otherwise the whole thing gets damp and starts to rot.
Lily
27 Jan 2009 08:49
Hi,
Egon is absolutely right, you need to properly treat the wood; otherwise, moisture will get in quickly, and it will deteriorate fast 😀. But the foundation is also very important, because otherwise moisture will come up from below quickly.
Best regards, Pippin
Lily
27 Jan 2009 12:59
Hi,
my neighbor also built a house like this, but he built the first 25 cm (10 inches) with masonry. He says that way he doesn’t have any problems with moisture.
I hope this helps you!
Regards, Lady
