Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
Bookstar
22 Aug 2018 07:42
Yes, that’s what I mean, because it is uncommon to build a heated garage. But of course, it is not impossible.
Goldi09111
22 Aug 2018 07:50
Oh, of course, the garage is not part of the thermal envelope; otherwise, it would already be insulated, including the roof.
Steffen80
22 Aug 2018 07:59
We insulated our garage. Inside, there is water supply and heating. Humidity is monitored via KNX, and if needed, a roof window opens slightly for ventilation.
Bookstar
22 Aug 2018 09:55
Then the question is, what actually gave you the idea to insulate the roof? That would be quite pointless..
hstkai
22 Aug 2018 09:56
To keep the garage frost-free during winter, I also added insulation. Insulation installed, vapor barrier underneath... Result: garage stays frost-free in winter. However, in summer the insulation started to sweat. As a solution, I created ventilation between the insulation and the roof covering and replaced the vapor barrier with a variable vapor retarder. Now I hope it really works.
Goldi09111
22 Aug 2018 11:05
That’s exactly the point: the garage stays frost-free in winter, and you can work on projects without the heat from, for example, a gas heater being wasted immediately.
@hstkai, how did you handle the ventilation? Do you have some pictures of it?
