Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
R.Hotzenplotz
25 May 2018 22:47
If you use white tiles like those in a butcher shop, then certainly.
Personally, I have installed tiles in apartments where only half of the wall was tiled. You could immediately see scratches, dirt, or something similar on the untiled walls, and overall it looked unfinished to me.
Eldea
25 May 2018 22:53
blaupuma schrieb:
It’s all a matter of personal taste.
To me, it looks like you’re about to slaughter a cow there. You could just steam clean it on a large scale with a pressure washer.
Okay, that was a bit exaggerated.
But definitely over the top [emoji12] I’ve never seen a slaughterhouse with somewhat larger tiles. [emoji202][emoji243][emoji233][emoji230]
For example, I don’t like half-tiled bathrooms. If it were up to me, even the guest bathroom would be fully tiled. Here, the transition from ceiling height to 1.5m (5 feet) already annoys me.
And if I’m going to choose many concrete tiles, at least I could stand out from the crowd with full-height tiling.
But you’re right, because of the fully tiled walls, the corner currently lacks contrast. However, if the shelf surfaces are changed to gray and a bathtub tray is added, it will look better visually. Who knows, maybe a shelf will be added later, but it will have to match the gray furniture.
blaupuma25 May 2018 23:47
Bathroom with bathtub, gray tiles, window with wooden frame, and small lampshade.
Currently, it is set up like this.
It is a shower tray.
25 May 2018 23:55
R.Hotzenplotz schrieb:
If you use white tiles like in a butcher shop, then definitely.
Personally, I have installed tiles in apartments where the tiling only went halfway up the wall. You could immediately see scratches, dirt, or similar marks on the un-tiled parts of the walls, and to me, it looked unfinished.
Just because a wall isn’t tiled doesn’t mean it will automatically get scratches or similar damage... otherwise you would have to tile a living room or bedroom too *laughs*
11ant26 May 2018 00:20
blaupuma schrieb:
To me, it looks like you’re planning to slaughter a cow there.
I’m thinking more along the lines of “acoustic construction in the sense of a bathtub Caruso.”
haydee
26 May 2018 05:41
Our old butcher’s area was not tiled all the way up.
