Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
R.Hotzenplotz
27 May 2018 13:30
New photos of our construction progress today.
This is the area where a small flat roof will be installed above the kitchen bay.
Construction site: orange brick wall, perforated bricks resting on the scaffolding, narrow walkway.
View into the children’s bathroom:
Shell interior with concrete and brick walls, wooden roof frame, and window openings
Children’s room:
Unfinished interior of a new build with block walls, wooden beam ceiling, and scaffolding in front of windows
Upstairs hallway:
Unfinished interior on a construction site: white blocks, wooden ceiling, open stairwell, construction debris
Seating area on the roof terrace:
Shell of a balcony with wooden roof frame, green insulation boards, and scaffold netting.
View from the master bedroom towards the dressing room and master bathroom:
Shell interior with concrete block walls, wooden ceiling, open passage, and a block on the floor.
The door to the garage, which has meanwhile been bricked up. It was agreed to install a lintel so a door can still be fitted later if needed, although I don’t expect that to happen. I’m not sure if it was a good idea to use Poroton bricks here instead of aerated concrete blocks.
Shell: left brick wall, right concrete wall, green foil with Styrodur block, construction dust.
Overview of the ground floor hallway, showing the coat area and the guest WC on the left:
Interior of a construction site: white concrete blocks, orange brick walls, buckets and materials.
View into the living room:
Interior space with many supports, raw concrete floor, and brick walls; window with view of greenery.
The garden still looks like a battlefield:
Construction site with scaffolding and wood piles; view from the balcony to the garden and house in the background
11ant27 May 2018 13:47
Goldi09111 schrieb:
Why isn’t the hose connected directly next to the reel?
Or the other way around, yes, that’s what I was about to ask.
R.Hotzenplotz schrieb:
I’m not sure if it made sense that they apparently used Poroton blocks for this instead of aerated concrete blocks.
The way they did it, it might be just as "precise" to chisel it out. You just have to accept that.
bortel
27 May 2018 14:07
Modern Dark by Flairstone
Yes, the hose... at the connection point, the water comes directly from the cistern for free. The connection was there from the start... we added the others later for the drinking water as a backup. During planning, I didn’t yet know I would have a hose reel like that or where I would attach it [emoji2][emoji6]
The facade is insulated... so I didn’t want to drill into it or I should have known much earlier.
Well... not everything can be planned in detail [emoji85]
11ant27 May 2018 14:14
bortel schrieb:
The facade is insulated... I didn’t want to screw anything onto it, or I should have known that much earlier
I’m just saying, if it’s not fastened securely, it won’t hold.
bortel
27 May 2018 14:50
Oh, there are worse things than rerouting the hose [emoji2]
11ant27 May 2018 16:49
... to trip over the hose hanging on the wrong side next to the door, for example.
