Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
haydee
27 May 2018 22:59
Actually, the hose holder is not the problem; the two faucets should have been installed next to each other.
NeuerNachbar
27 May 2018 23:25
Müllerin schrieb:
Well, obviously, you should minimize drilling through insulation, right?
But the insulation is pierced in many places: windows, ventilation inlets and outlets, outdoor power outlets, light switches, doorbells, camera cables, faucets, and much more. I still don’t understand.
11ant27 May 2018 23:35
The issue is that securing something through the spray foam insulation is a major challenge. That’s why the hose holder is attached to a wall without insulation.
ruppsn
28 May 2018 00:56
The issue is that fastening something through expanding foam is a real challenge. That’s why the hose holder is attached to a wall without insulation.
There are telescopic brackets for this, so no need to worry. Please don’t overdramatize just because you’re not familiar with external thermal insulation composite systems (ETICS), which I can understand.
bortel
28 May 2018 05:45
Yes, exactly, I should have known that a hose holder would be installed on the facade during the insulation work. In that case, a telescopic bracket would have been installed there first, and later the hose holder.
@haydee figured it out correctly, but it would have been ideal if the two valves were next to each other. Since the one on the facade was planned beforehand and the other was added later, unfortunately, it was too late.
Alex85
28 May 2018 07:36
Müllerin schrieb:
Well, you should drill as little as possible through insulation, that’s clear, right? That’s why the conduit is attached to the wall, not the house.
Just as little as you would in a solid stone wall. You can even chase that from the inside. What a sacrilege.
Attaching the conduit holder in front of the external thermal insulation composite system (ETICS) should not be a problem. Appropriate screws and that’s it.
