Alessandro9 Dec 2020 13:43Matthias 40 schrieb:
@Toooias:
The railing is painted black. It has some advantages: it can be easily touched up and it is cheaper. According to my metalworker, powder coating the railing would have been very complicated because it is so large. I like the look, even if some paint chips off occasionally, it matches the fireplace even better then.Your metalworker definitely misled you there. Powder coating is quite simple and relatively affordable. He probably just didn’t have the right equipment for it…
I have a similar-sized and much more complex railing. It was no problem at all…
Schimi1791 schrieb:
The shower looks like this (still without the built-in cabinet):Yeah, much better. That plain gray with those 70s patterned tiles... you just don’t see that anymore. The accents with the black frames and the green fixtures... very modern!
Alessandro schrieb:
Your metalworker must have misled you. Powder coating is quite straightforward and relatively inexpensive. He probably just didn’t have the right equipment for it...
I have a similar size and a much more complex railing. It was no problem at all... Simple? Well... 🙂 I know the effort involved with garage doors...
face26 schrieb:
Yeah, much better. That dull gray with those 1970s ornamental tiles... you just don’t see that anymore. The accents with the black frames and the green fixtures... very modern!
😉 Good thing the pictures are properly labeled! Although... green fixtures? Bold choice of color! 🙂
(strictly speaking, the fixtures are green-purple)
Alessandro9 Dec 2020 14:27Schimi1791 schrieb:
Simply put? Well ... 🙂 I know the effort involved with garage doors ...There is no easier method to apply a coating uniformly on a structure like a railing, which has many edges and weld seams.
My steel stringers were painted—three thick coats in total. It was very time-consuming, partly because of the drying times.
By comparison, powder coating is a simpler process.
It is also much more durable overall.
- Previous
- 1
- 2
- 3
- 10
- 20
- 30
- 40
- 50
- 60
- 70
- 80
- 90
- 100
- 110
- 120
- 130
- 140
- 150
- 160
- 170
- 180
- 190
- 200
- 210
- 220
- 230
- 240
- 250
- 260
- 270
- 280
- 290
- 300
- 310
- 320
- 330
- 340
- 350
- 360
- 370
- 380
- 390
- 400
- 410
- 420
- 430
- 440
- 450
- 460
- 470
- 480
- 490
- 500
- 510
- 520
- 530
- 540
- 550
- 560
- 570
- 580
- 590
- 600
- 610
- 620
- 630
- 640
- 650
- 660
- 670
- 680
- 690
- 700
- 710
- 720
- 730
- 740
- 750
- 760
- 770
- 780
- 790
- 800
- 810
- 820
- 830
- 840
- 850
- 860
- 870
- 880
- 890
- 900
- 910
- 920
- 930
- 940
- 950
- 960
- 970
- 980
- 990
- 1000
- 1010
- 1020
- 1030
- 1040
- 1050
- 1060
- 1070
- 1080
- 1090
- 1100
- 1110
- 1120
- 1130
- 1140
- 1150
- 1160
- 1170
- 1180
- 1190
- 1200
- 1210
- 1220
- 1230
- 1240
- 1250
- 1260
- 1270
- 1280
- 1290
- 1300
- 1310
- 1320
- 1330
- 1340
- 1350
- 1360
- 1370
- 1380
- 1390
- 1400
- 1410
- 1420
- 1430
- 1440
- 1450
- 1460
- 1470
- 1480
- 1490
- 1500
- 1510
- 1520
- 1530
- 1540
- 1550
- 1560
- 1570
- 1580
- 1590
- 1600
- 1610
- 1620
- 1630
- 1640
- 1641
- 1642
- 1643
- 1644
- 1645
- 1646
- 1647
- 1648
- 1649
- 1650
- 1651
- 1660
- 1670
- 1680
- 1690
- 1700
- 1710
- 1720
- 1730
- 1740
- 1750
- 1760
- 1770
- 1780
- 1790
- 1800
- 1810
- 1820
- 1830
- 1840
- 1850
- 1860
- 1870
- 1880
- 1890
- 1900
- 1910
- 1920
- 1930
- 1940
- 1950
- 1960
- 1970
- 1980
- 1981
- 1982
- 1983
- Next
