Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
i_b_n_a_n3 Jun 2022 08:01
Hi, just as a side note: The roughly 60m² (650 sq ft) are not for “us” but for “me”...
Thanks, the curtain is enough. But it’s still the provisional one from 8 months ago until I find a nicer one 😉
Aloha_Lars
3 Jun 2022 08:50
Pinkiponk schrieb:
I have a question about your shower solution. Is the shower curtain enough to prevent water from flooding outside the shower area? We might consider a similar setup but are unsure because several expert forums advise against it. Thanks in advance for your answer. 🙂
We have a tiled walk-in shower with only a shower curtain. There is no flooding outside the shower. You just need to make sure there is only a small gap between the curtain and the floor. Then it works well.
Ypsi aus NI
3 Jun 2022 09:52
We have now experienced our first delay on the construction site. The floor insulation was not available, so work was halted for two weeks. Considering the overall construction pace, this is absolutely manageable.
From the outside, the house has been finished for weeks now (masonry work started on January 5). We really like the brickwork; the joints are done neatly. The photovoltaic system has been installed for a while, not with full black-black modules, but I still like how it looks.
The wiring is only for the ground floor; there is another technical room on the upper floor. The floor is currently covered with numerous cables, pipes, and conduits. Entering the construction site is quite difficult at the moment.
The tiles have been chosen to match the kitchen cabinets, ordered, affordable, and will arrive in two weeks.
Both the tilers and painters have availability within the right time frame. As good as it sounds, I hope it continues like this :-)
Viele lose Kabel und Schlaufen hängen von der Decke; Kabelrollen liegen auf dem unfertigen Boden.
Rote Ziegelsteinwand mit grauen Fugen in normalem Mauerverband.
Unfertiger Innenraum mit Kabelbündeln und Rohren auf staubigem Boden vor einer weißen Tür.
Baustelle mit vielen Kabeln: Kabelstränge liegen auf dem Boden, Blick durch Durchgang zum Fenster im Hintergrund.
Bodenfliesen-Muster: Holzoptik links, rostmetallische Fliesen in Mitte/Rechts, kleine Musterkarten.
Dach mit Solarmodulen auf dunkelgrauen Ziegeln, Kamin und Baukran am blauen Himmel.
TmMike_2
3 Jun 2022 10:06
@Ypsi aus NI The electrician apparently didn’t feel like running the cables through the ceiling and chasing into the calcium silicate bricks, right? 😀
Deliverer
3 Jun 2022 10:17
Ypsi aus NI schrieb:
The photovoltaic system has been installed for a long time,
They should go back on the roof again; it feels like about 20 more modules are still missing! ;-)
Ypsi aus NI
3 Jun 2022 10:27
Deliverer schrieb:
They should still put some on the roof, it feels like 20 modules are missing! ;-)
We have 43 modules, nearly 18 kWp.
Installing behind the chimney doesn’t make sense because of shading. The picture in the previous post shows the west side. The east side is fully covered on both sides, see this post. But I agree with you: a few more modules would have fit 😉
Roof of a house with photovoltaic solar system on gray tiled roof
