ᐅ Are electrical cables allowed to be installed under a shower?
Created on: 3 Jan 2019 23:14
blaupuma
blaupuma3 Jan 2019 23:14
we are currently building, and the electrician has installed a cable under our shower. The cable then runs up through the shower wall and through the exterior wall (outdoor light).
Now I’m wondering if this is actually allowed?
The electrician says it is.
So the cable lies on the base slab.
There will be screed and insulation on top of it, and plaster and tiles on the wall.
(The cable is chased into the masonry.)
Nordlys
4 Jan 2019 09:33
So what? What is the objection?
Knöpfchen4 Jan 2019 10:40
I’m still not quite sure what to make of this. The cable runs along the floor, and the shower will later be installed on top of it. Now the cable goes up the wall, chiseled into the masonry, and this wall is directly inside the shower area?
blaupuma4 Jan 2019 13:15
Yes, it goes up the wall, channeled into the exterior wall (Ytong), then through the outer layer.
This means it will be filled in, then covered with 15 mm (0.6 inch) of lime-cement plaster, plus tiles. The shower will be installed there.
Nordlys
4 Jan 2019 13:19
and that is completely safe. The cable is insulated. There is plaster over it. Tiles on top... just think about it.
Lumpi_LE
4 Jan 2019 14:08
An electrical outlet has no place in a shower; the cable is completely irrelevant.
