motorradsilke24 Jun 2022 21:08Pinkiponk schrieb:
I’m imagining a rather nostalgic mailbox, something like in the photo, but I’m not yet sure exactly where on the property we will place it, since we haven’t finalized the path layout yet. As far as I know, it needs to be set in concrete and I don’t want or need to move it later.
[ATTACH alt="haus-bilderthread-zeigt-her-eure-hausbilder-582115-1.jpg"]72891[/ATTACH]Then buy an inexpensive exposed aggregate concrete slab from the home center, dig a hole where you think it can go for now, and place it on that. Later you can make a proper concrete foundation at the final location. However, this should not be on the property itself, but in front of it. You don’t want the mail carrier going onto your property all the time, do you?
motorradsilke schrieb:
Then buy a cheap exposed aggregate concrete slab from the home improvement store, dig it in where the mailbox can be placed temporarily, and set it on top. Later, you can build a concrete foundation for it at its final location. However, not on your property, but in front of it. You don’t want the mail carrier to have to enter your property every time, right? In our area, it’s common for the mailbox to be near the front door. Probably so that you can collect mail without attracting too much attention, and also to consider the weather.
A standard mailbox with a newspaper holder. There will likely be some beams, boards, or similar materials on your construction site that you can use to nail a post. The mailbox can then be attached to this post. The base of the post can be weighed down with concrete slabs to ensure it is storm-proof. It’s advantageous if the mailbox can be set up flexibly, as you might need to work in different locations from time to time.
bauenmk2020 schrieb:
At our place, it’s common for the mailbox to be located near the front door. Probably so you can collect the mail without attracting too many curious looks. Are people reluctant to step outside your front door? 😀
If the property is fenced, the mailbox is usually placed by the gate; if the access is open, then close to the front door is preferred.
Better the mail carrier gets wet than the person collecting the mail.
This also allows for picking up the newspaper early in the morning, almost straight from bed.
Pinkiponk schrieb:
What do/did your transitional mailboxes look like? At first, it was a retired kitchen step trash bin, with the house number displayed in A4 size.
Months later, the mailbox was mounted on the facade under the porch roof, with the house number integrated into a light fixture.
motorradsilke25 Jun 2022 08:11bauenmk2020 schrieb:
In our area, it is common for the mailbox to be located near the front door. Probably so you can collect your mail without attracting too much attention.However, this only works if your property is not fenced. Most of the properties here are fenced, so I would have to leave the gate open to allow the mail carrier access to the property.
WilderSueden25 Jun 2022 09:42There are also garden gates where you can reach the handle from the outside 😉
WilderSueden schrieb:
There are also garden gates where you can reach the handle from the outside 😉And fortunately, there are also garden gates without handles, to keep out roof renovators, conservatory sales teams, and the like.- Previous
- 1
- 2
- 3
- 10
- 20
- 30
- 40
- 50
- 60
- 70
- 80
- 90
- 100
- 110
- 120
- 130
- 140
- 150
- 160
- 170
- 180
- 190
- 200
- 210
- 220
- 230
- 240
- 250
- 260
- 270
- 280
- 290
- 300
- 310
- 320
- 330
- 340
- 350
- 360
- 370
- 380
- 390
- 400
- 410
- 420
- 430
- 440
- 450
- 460
- 470
- 480
- 490
- 500
- 510
- 520
- 530
- 540
- 550
- 560
- 570
- 580
- 590
- 600
- 610
- 620
- 630
- 640
- 650
- 660
- 670
- 680
- 690
- 700
- 710
- 720
- 730
- 740
- 750
- 760
- 770
- 780
- 790
- 800
- 810
- 820
- 830
- 840
- 850
- 860
- 870
- 880
- 890
- 900
- 910
- 920
- 930
- 940
- 950
- 960
- 970
- 980
- 990
- 1000
- 1010
- 1020
- 1030
- 1040
- 1050
- 1060
- 1070
- 1080
- 1090
- 1100
- 1110
- 1120
- 1130
- 1140
- 1150
- 1160
- 1170
- 1180
- 1190
- 1200
- 1210
- 1220
- 1230
- 1240
- 1250
- 1260
- 1270
- 1280
- 1290
- 1300
- 1310
- 1320
- 1330
- 1340
- 1350
- 1360
- 1370
- 1380
- 1390
- 1400
- 1410
- 1420
- 1430
- 1440
- 1450
- 1460
- 1470
- 1480
- 1490
- 1500
- 1510
- 1520
- 1530
- 1540
- 1550
- 1560
- 1570
- 1580
- 1590
- 1600
- 1610
- 1620
- 1630
- 1640
- 1650
- 1660
- 1670
- 1680
- 1690
- 1700
- 1710
- 1720
- 1730
- 1740
- 1750
- 1760
- 1770
- 1780
- 1790
- 1800
- 1810
- 1820
- 1830
- 1840
- 1850
- 1860
- 1870
- 1880
- 1890
- 1899
- 1900
- 1901
- 1902
- 1903
- 1904
- 1905
- 1906
- 1907
- 1908
- 1909
- 1910
- 1920
- 1930
- 1940
- 1950
- 1960
- 1970
- 1980
- 1981
- 1982
- 1983
- Next
