Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
Z
Zaba12
2 Jun 2019 16:19
LaloBau schrieb:
We are making good progress.... The excavated soil has been backfilled, the ground floor is up, and tomorrow the ceiling will be installed. Today, I stood for the first time in the future garden.... absolutely huge
[ATTACH alt="IMG_2180.JPG"]34967[/ATTACH]
Dining room window with basement light well
[ATTACH alt="IMG_2182.JPG"]34968[/ATTACH]
View into the living room
[ATTACH alt="fullsizeoutput_1e24.jpeg"]34969[/ATTACH]
Dining room “wart” and living room windows from the garden side
Either you got a bad batch of bricks or the masons are not working precisely. None of the rows have bricks properly aligned on top of each other. The plasterer is going to have a hard time. And I’ve never seen corners finished like that before (with the cut edges facing outward).
derkobi
2 Jun 2019 19:18
I had exactly the same thought @Zaba12
But it’s almost impossible to carry out the work like that, isn’t it?
What’s wrong there?
Milo3
2 Jun 2019 19:27
derkobi schrieb:
I was thinking exactly the same, @Zaba12
But it seems almost impossible to do the craft properly?
What’s wrong here?
Everything is fine. They can do it either way, meaning that if they place the level on one side, the other side will look less precise. The bricks all have a height tolerance of about -1cm (0.4 inches) for an average person.
Lumpi_LE
2 Jun 2019 19:28
It really looks like they were completely out of their minds while doing the brickwork...
Z
Zaba12
2 Jun 2019 19:31
Milo3 schrieb:
Everything is fine there. They can do it either way, meaning they place the level on one side and the other side then looks less precise. The bricks all have a height tolerance of about -1cm (0.4 inches) for the average person.
In my case, it didn’t look like that either outside or inside. They didn’t even manage to get the last row of bricks below the ceiling straight!
Milo3
2 Jun 2019 19:56
Zaba12 schrieb:
It didn’t look like that for me either, neither inside nor outside. They didn’t even get the top row of bricks straight below the ceiling!
Maybe you got lucky with the bricks. Both the Wienerberger and the Juwö bricks have this variation. How are they supposed to get it right when one brick is 36.5cm (14.4 inches) wide at the bottom and 35.8cm (14.1 inches) at the top, or when the bricks have a curve in the middle?!
